Greenley Posted November 5, 2016 Share Posted November 5, 2016 99 Legacy Brighton PhaseII EJ22 5 MT AWD I need some help diagnosing an issue that is perplexing- Subie starts fine- when i depress the clutch pedal (it feels normal) put it into gear, nothing happens. Nothing at all. I am able to shift through all gears with no sign of engagement. I have burnt a clutch out on an older GL, and was able to use the starter to move the car- Which leads me to believe that it may be something else wrong here- Any suggestions on what i can do to diagnose the issue and get this daily driver back on the road? 1 Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 5, 2016 Share Posted November 5, 2016 Unless something broke, like the input shaft, or the clutch disc itself, I'm not sure what would cause this. You're positive its going into the gears. And the car will roll with the e-brake off? 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 6, 2016 Share Posted November 6, 2016 broken axle? Link to comment Share on other sites More sharing options...
Greenley Posted November 6, 2016 Author Share Posted November 6, 2016 (edited) On 11/5/2016 at 11:34 PM, crazyhorse001 said: Unless something broke, like the input shaft, or the clutch disc itself, I'm not sure what would cause this. You're positive its going into the gears. And the car will roll with the e-brake off? Im certain its going into gears- with the car in the air, the wheels *very* slowly move forward in 1st and backwards in Reverse. The car rolls IN gear with the e-brake off. Edited November 6, 2016 by Greenley Link to comment Share on other sites More sharing options...
Greenley Posted November 6, 2016 Author Share Posted November 6, 2016 On 11/6/2016 at 12:40 AM, 1 Lucky Texan said: broken axle? All the axles feel as they should. no play outside of normal tolerances, boots intact and a solid connection to the diff stubs and hubs Link to comment Share on other sites More sharing options...
forester2002s Posted November 6, 2016 Share Posted November 6, 2016 (edited) Clutch-fork: - with no force on the clutch-pedal, can you manually move the top of the clutch-fork to the rear? Should be able to feel some looseness/movement. - with clutch-pedal partially-depressed, can you move the top of the clutch-fork? - with clutch pedal fully-depressed, can you move the top of the clutch-fork? What I'm thinking is the possibility that: - as the clutch-fork moves, the bottom-end of the fork and the throw-out bearing may not be moving as they should; or - the clutch-plate is stuck in the disengaged position, and the fork & bearing are moving but not actually doing anything. I realize that none of this fits with your description that that clutch-pedal feels normal. Edited November 6, 2016 by forester2002s Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 7, 2016 Share Posted November 7, 2016 My guess is going to be the clutch disc is past it's wear limit. Any issues with it before it stopped moving? Link to comment Share on other sites More sharing options...
Greenley Posted November 7, 2016 Author Share Posted November 7, 2016 On 11/7/2016 at 12:39 AM, Caboobaroo said: My guess is going to be the clutch disc is past it's wear limit. Any issues with it before it stopped moving? Its made a slight 2 second chattering sound upon ignition for the past year- Probably a loose spring on the disc and it finally gave up the ghost? I think youre right though, saw bits of disc once i pulled the starter out and inspected it. An exedy kit is in the mail, I'll report back when i get it seperated. Link to comment Share on other sites More sharing options...
Greenley Posted November 28, 2016 Author Share Posted November 28, 2016 in closure, it was just the clutch disc which was worn down to the rivets. Link to comment Share on other sites More sharing options...
