2009 Forester rebuild, or replace?
First time poster, long time lurker.
Back in 2009 I purchased a 2001 Forester for $2K and drove it for about 18 months, and then foolishly traded it in for a 2005 Honda Pilot. We still miss that little green Forester to this day.
I am just about to purchase a 2009 Forester for the, what seems like a bargain price of $2000. 120K on it. But it seems it has a knock. I have not yet heard it myself. This will be purchased from a family member.
Now, to preface my question... I am a toolmaker by trade, but started my machining career in an automotive machine shop. Rebuilding everything from Kohler single cylinder engines, to straight 8 Buicks, cat diesels, and even a 412 Rolls Royce V8(which was $4K just in PARTS back in 1986).
SO, I have a couple of questions for those far more experienced in Subarus.
1.) It seems to be well worth the price of admission for $2k. Considering good running Foresters in my area are catching about $6500-$8000 with 120K on the clock. KBB trade in value of $5300.
But is it really worth it?
2.) I've been reading and watching a few  videos on rebuilding the Subaru 2.5L. Doesn't seem overly daunting. But it's harder than a typical 4 cyl. Considering you have to split the cases.
Should I rebuild? Or should I just purchase a reconditioned short block?
One reason for tackling this, is a would be a good project for my 15 year old and I to have a project to do together. Teach him a little bit about cars, and a little less video game time!
Thanks in advance.
Rebuild it.  Splitting the case seems daunting but its not bad at all. Make sure you have a heavy duty 1/2 " drive 14mm 12 point  (snapon calls it the subaru head bolt socket) A ,TP-40 torx plus for the head caps. And buy subaru case o rings and block sealing washers as well as only subaru head gaskets. Good project for you & the boy.
www.car-part.com check for a yard engine.  Your son will still learn a bunch from the engine replacement.
There are a bunch of USMB members that rebuild engines full time.
I work on older stuff 96-99 Outbacks were I can find a good used 2.2 for $300 and drop it in with new seals, timing belt... for under $500.
