EA82 engine noise video
Hi everyone,
A few weeks ago I noticed a noise in my engine. Oil level at the time was normal and dark. I then changed the oil and filter with my normal 10w40. Still has a very audible noise coming from the driver cylinder head. I replaced the distributor assuming a bad bearing because most, if not all of the noise was heard there through my stethoscope. Not the case, so I re-installed the original distributor and am back to square one.
Please view my video and if you want, you can jump to minute 3:15. The audio did not turn out that well for the warm up, but sounds better at minute 3:15.
Thank you for your help and any input would be helpful.
Will
Alright I have an exciting update!!
Yesterday I removed the driver side timing cover and found that the driver side timing belt was really loose...about 1-inch of travel up and down. A lot of slack. So today I removed the passenger timing cover and the passenger timing belt had better tension but still a little bit of slack. So now for the exciting part! I reset the tension on both timing belts and fired it up. No more noise and now this little motor purrs better than before! Definitely a relief and piece of mind. Maybe the slack in the driver timing belt was causing free play somewhere inline of the distibutor during idle...don't know for sure. All I know is that my belts are tensioned properly and the noise is gone! There is about 30k on these belts so I think they stretched a bit. Anyways I hope this may help anyone out there with an engine noise, and that I recommend them to check the timing belt tension FIRST!
Thank you!
Maybe  the water pump going out - that would also be a rotational bearing type noise.    If you can safely listen to the pump with your stethoscope,  it would be worth ruling it out.
--Never mind, you posted your update while I was watching the video .. Glad you found it.
Edited by Dee2
