chancho75 Posted November 12, 2016 Share Posted November 12, 2016 Took my subie in for smog check and didn't pass bc it has two codes and the CEL isn't illuminating. I just got the car as a gift. PO didn't fix the problem. Not sure what he did. I have replaced all the bulbs and the battery is the only one illuminating. If you guys can help me out I would really appreciate it. Thank you Link to comment Share on other sites More sharing options...
chancho75 Posted November 12, 2016 Author Share Posted November 12, 2016 This is for a 1997 subaru outback Link to comment Share on other sites More sharing options...
dp213 Posted November 12, 2016 Share Posted November 12, 2016 When you first turn the key to on position without starting, do the cel and break, and other lights on the dash come on for a moment Link to comment Share on other sites More sharing options...
chancho75 Posted November 12, 2016 Author Share Posted November 12, 2016 The brake light doesn't turn on when e-brake is on. The only light that is on with key on engine off is the battery light. Link to comment Share on other sites More sharing options...
wtdash Posted November 14, 2016 Share Posted November 14, 2016 On 11/12/2016 at 12:51 AM, chancho75 said: Took my subie in for smog check and didn't pass bc it has two codes and the CEL isn't illuminating. I just got the car as a gift. PO didn't fix the problem. Not sure what he did. I have replaced all the bulbs and the battery is the only one illuminating. If you guys can help me out I would really appreciate it. Thank you You pulled the dash console (speedo/Tach) and replaced those bulbs, correct? And all the plugs on the back are plugged in? If so, I don't know why they wouldn't work, but you may want to find another console to @ least test it. Any '95-'98 Legacy shouls work, but you may want to stick w/the '96-'98 OB or GT models for best compatibility w/the 2.5 engine and such. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 14, 2016 Share Posted November 14, 2016 (edited) battery light is in a special circuit I think so, I'd be looking for a bad ground or some fuse(s) bad. I wouldn't rule-out something odd with the illumination module. Edited November 14, 2016 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
