Check engine light not illuminating
Took my subie in for smog check and didn't pass bc it has two codes and the CEL isn't illuminating.
I just got the car as a gift. PO didn't fix the problem. Not sure what he did.
I have replaced all the bulbs and the battery is the only one illuminating.
If you guys can help me out I would really appreciate it.
Thank you
Thank you
You pulled the dash console (speedo/Tach) and replaced those bulbs, correct? And all the plugs on the back are plugged in?
If so, I don't know why they wouldn't work, but you may want to find another console to @ least test it. Any  '95-'98 Legacy shouls work, but you may want to stick w/the '96-'98 OB or GT models for best compatibility w/the 2.5 engine and such.
