tom3 Posted November 14, 2016 Share Posted November 14, 2016 Good day sir, here is the email requested. Vehicle arrived at shop by tow truck. Vehicle at first would start every time.. ( noticed left rear brake lineleaking and advised customer/left rear tire).. unable to duplicate no startconcern.. after 3rd or 4th day finally got the vehiclenot to start. Checked compression( cyl #1 135psi, cyl #2 130psi, cyl3 and 4 at135psi(slightly low but not low enough to cause a problem) Checked for fuel,did have correct fuel pressure), vehicle was getting no spark( to the plugs). Spark was coming from the coil to the distributor(nothing from distributor toplugs). Checked power and ground to distributor, to make sure when vehiclecranking over, ecm saw signal.. it did not. The crank angle sensor on thedistributor was not showing output. Took timing belt covers off to be sureeverything ok. No concerns, no slip/break, all within specs. Tested with knowngood distributor at this point. Vehicle started at that point but ran for about10 seconds then shut off. Again, no spark to plugs. Retested everything asbefore, then found no spark coming from ignition coil. Checked resistance inthe coil to see if ok( primary side had .8 ohms and spec is .8-5 ohms/ checkedsecondary side.. had 17.1 kohms.. spec is 8-12kohms). at this point installedand tested with a known good coil. Oem coil went to .9 on primary and secondarywent to 11kohms. still no spark from coil. At this point all specs are withinranges on all systems and no spark from coil. At this point is where the trailended. Note: the dealer has had the car for over a month, tested it with new distributor, new coil, etc., and still has not got it to keep running. There is/has been intermittant spark. I thought it might be a ground or possible bad wire/connection from the ignition module, but they haven't found any so far. Car went in 9/23... still there, but they said "come get it, we quit":-( Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 14, 2016 Share Posted November 14, 2016 details on car? year/miles/condition etc. Link to comment Share on other sites More sharing options...
tom3 Posted November 15, 2016 Author Share Posted November 15, 2016 1991 Subaru Loyale wagon: 220,979 mi. (1428 since new timing belts). VIN JF1AN4220MB417193 Car ran very well before it quit... no oil consumption, excellent acceleration, no misfiring. It has been well maintained. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 15, 2016 Share Posted November 15, 2016 You'll want to post this on the old gen section where the EA engine guys can give you better advice. Shouldn't be that hard to figure this out. There are only a few components that control spark, but I don't know enough details about that engine to be of much help. Link to comment Share on other sites More sharing options...
john in KY Posted November 15, 2016 Share Posted November 15, 2016 The coil bracket has to be grounded. Remove/clean/replace and see if that solves the problem. Link to comment Share on other sites More sharing options...
somick Posted November 15, 2016 Share Posted November 15, 2016 Yes, post it in the "Older Generation" As far as I know they have different distributors for different years. So make sure you are testing it with the correct one. There is a transistor mounted next to the coil. You may also need to get a known good one and test it. Good luck, Sam Link to comment Share on other sites More sharing options...
DaveT Posted November 15, 2016 Share Posted November 15, 2016 Try starting and running while holding the throttle slightly open. If it dies only when you let it go to idle, it may be in the iac circuit. I had one do that. 1 Link to comment Share on other sites More sharing options...
Dee2 Posted November 15, 2016 Share Posted November 15, 2016 sounds very much like a grounding problem. Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 15, 2016 Share Posted November 15, 2016 Ignitor. You'll get spark once, then not again till key off/on ycle. Link to comment Share on other sites More sharing options...
