tucka786 Posted November 15, 2016 Share Posted November 15, 2016 I'm picking an old project up again and need some help to test a EA81 engine on a test stand . I have the engine running on the test stand for a very short while as the cooling radiator was not connected . I'd like to test the engine for longer and connect the radiator and water pipes . I've connected the radiator main pipes to the water pump ans thermostat housing on the manifold . I need some advice on the 2 heater hoses , one coming from the water pump and the other from the manifold ? Can I connect these hoses together so the water flows around the engine as I will not be using a heater core ? Also should I leave the cooling fan on the radiator running on constantly as I test the engine to avoid any overheating ? Any help / advice appreciated . Thanks . Tucker Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 15, 2016 Share Posted November 15, 2016 Loop of hose for the heater, yes. Fan running on the radiator is a good idea. 1 Quote Link to comment Share on other sites More sharing options...
