imo Posted November 18, 2016 Share Posted November 18, 2016 Hi there, My Subaru Lancaster (same as Outback) has just died, I can't get it to go further than a couple of kms and don't want to try as it has a few engine lights coming on and revs keep dropping etc. My main question here is how can I tow it? I know the recommendation is to put it on a flatbed but that will cost a lot, I have also found a video showing me how to insert a fuse to change it to 2 wheel drive. If I do this can I tow it with all wheels on the ground? The distance to the mechanic is about 15km. Cheers Link to comment Share on other sites More sharing options...
Rooster2 Posted November 18, 2016 Share Posted November 18, 2016 No, the fuse changing to 2 wheel drive still does not permit towing with 2 wheels on the ground. Flat bed towing, or towing with car on a trailer with all wheels off the ground is still needed. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 18, 2016 Share Posted November 18, 2016 (edited) I assume you have an automatic? What year? anyway - you're likely to overheat transmission fluid and some vital parts if you tow it. The FWD fuse only 'works' when the engine is running. the 5 spd can be towed - best if done slowly for limited distances I think. Edited November 18, 2016 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
idosubaru Posted November 18, 2016 Share Posted November 18, 2016 pull it with another vehicle and a long chain in neutral. i do it in the middle of the night when they're no traffic. if it at least idles, let it idle whlie you're towing it so you have brakes, steering, and nominal operation/fluid movement. 1 Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 18, 2016 Share Posted November 18, 2016 If all else fails, remove the rear of the driveshaft from the differential. Tie the shaft to the exhaust, then you can tow it on a dolly. Link to comment Share on other sites More sharing options...
imo Posted February 7, 2017 Author Share Posted February 7, 2017 Thanks guys, ended up getting it picked up by prefessionals - was a fair way to tow anyway Link to comment Share on other sites More sharing options...
