Mindburn Posted November 19, 2016 Share Posted November 19, 2016 Based on my [limited] mechanical expertise, it is time to replace the head gasket in my 95 legacy wagon, 2.2L. At about 230,000, it instantly overheated and white clouds (antifreeze) went out the exhaust. There is also oil mixed with the coolant in the radiator when I changed the thermostat, hoping that was the only issue. So...its time. Also, the timing belt was replaced around 210,000, so im guessing thats not necessary again? A few things/questions: 1. There are many brands of the gaskets out there. I've heard only mixed reviews whether to go 0EM or not. So which a gasket kit should I get? I do not want to do the cheapest but I am on a budget. 2. Are there any online step-by-step instructions, a manual, or video on this? I tried the Google thing, and came up with nothing so please don't say "just Google it." Is the repair manual from parts store sufficient enough for this? It seems like they leave out a lot of details. Thanks for taking time to read this! Link to comment Share on other sites More sharing options...
DaveT Posted November 19, 2016 Share Posted November 19, 2016 My general thoughts. .. Get a factory service manual. I have used only oem or Fel Pro gaskets / sets. Others more familiar with that particular engine would be better at knowing if other things should be checked. That bad of overheat may indicate it wise to check a lot more than just resealing. Link to comment Share on other sites More sharing options...
dp213 Posted November 19, 2016 Share Posted November 19, 2016 2.2 motors are very easy to do. I have used 6 star head gaskets but they are pretty expensive, about $120 a pair, but they are very good. I have recently used the felpro permaflex gaskets. They seem good and reviews were good, but they have only been in for about a month so I can't say yet how they hold up. As for the work to be done, a store bought manual works pretty good. The important part is having the head surface prepped correctly, and the block. And also the torque sequence is important. If I can figure out how to attach a photo, I will post the sequence for you. Link to comment Share on other sites More sharing options...
montana tom Posted November 19, 2016 Share Posted November 19, 2016 ebay item number 141665882014 O. E. 2.2 subaru head gaskets $ 81.99 delivered Link to comment Share on other sites More sharing options...
idosubaru Posted November 19, 2016 Share Posted November 19, 2016 1. Subaru headgaskets (fel pro seem to be highly touted as reasonable replacements by folks on here in the past, i haven't used them) 2. resurface the heads - find the post on here and you can easily do it yourself. it's so simple 3. get the Subaru FSM - they're all over the internet for free those heads are really easy to replace - the headbolts are external and the easiest ones Subaru has ever made. remove timing belt unbolt power steering pump and a/c compressor and swing them both to the side of the engine bay (no need to disconnect the lines) unbolt exhaust manifold remove intake manifold - disconnect fuel lines, throttle cable, spark plugs, engine wiring harness connector, and alternator wiring, and ancillary grounds, etc. unbolt heads you can even do it in the vehicle - just unbolt the top pitch mount (one nut/bolt) and remove the two lower 14mm engine mount nuts - and jack the engine up a few inches. 1 Link to comment Share on other sites More sharing options...
forester2002s Posted November 19, 2016 Share Posted November 19, 2016 Your timing-belt should be OK, after only 20,000 miles, IF it was either OEM or other good make e.g. Gates. However, I've had two no-name T-Bs deteriorate badly soon after replacement. Check the T-B for surface transverse cracks, especially on the backside of the belt. Link to comment Share on other sites More sharing options...
Mindburn Posted November 19, 2016 Author Share Posted November 19, 2016 These are all great answers. Thank you. I just did some more reading about this, and the handful of people claim that some magical pour in sealant, similar to a fix a flat, is worth trying before replacing the head gaskets. But based on what is happening that I mentioned in the original post, it doesn't seem like just merely using a pour-in sealer would suffice. Any thoughts? Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 19, 2016 Share Posted November 19, 2016 Stay away from a fix in a bottle. It can actually lead to plugged radiators, plugged heater cores and more. If it has a bad head gasket, the easiest and best thing to do is replace it. No magic in a bottle solution will help but in fact make it harder on yourself. I've done hundreds of Subaru head gaskets with OEM or SIX Star. I've never been a fan of Fel Pro head gaskets as I've seen too many failures with them. Link to comment Share on other sites More sharing options...
idosubaru Posted November 19, 2016 Share Posted November 19, 2016 (edited) the fixes in a bottle *might* limp the car along for some unknown amount of time with severe downsides mentioned by caboob. they're like band aids - they're not long term, reliable solutions...if they help at all, they are going to come undone at some point in the future. It makes sense - ICE's are high temperature, pressures and cycling - 1,000+ degrees, 200 psi - roughly equivalent to woman in 1,000+ degree high heels stepping on your face. this isn't a simple, benign fluid loss situation, and it's almost comical to think it's an idea with excellent success rates. are they worth a shot in some situations? maybe in a rust rotted north east special with no chance of living more than 6 months. are they worth a shot in a financially desitute situation....i doubt it. a financially struggling person, IMO, needs to start making great long term financial decisions and quit thinking short term, and a solid car that can last another few years reliably is better than limping along, getting stranded again in 6 months, and needing some other cheap craigslist special that's going to cost more to maintain/fix repair than they can afford as well. there is a specific Subaru engine that responds well, in certain situations, to a Subaru Coolant Conditioner - that's a very specific engine, and even a very specific failure mode of that engine. It is by no means applicable to any other engines or failures modes. that boils down to physics and facts - not opinions. yours is not one of those engines nor one of those failure modes. you can include links to "readings" you find and we can address those more specifically though i imagine you're talking about the Subaru Coolant Conditioner or Blue Devil. Edited November 19, 2016 by grossgary Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 20, 2016 Share Posted November 20, 2016 None of the magic bottle stuff will fix these. Its likely the heads will need to be resurfaced, but you won't know for sure until they're off. Fel-pro makes the original head gaskets for that engine. They even have the Fuji heavy industries check logo on them. I buy them for about $25 a piece from advance auto with a discount code. The other gaskets can be pretty much any brand, but I will say that OE Subaru exhaust manifold gaskets tend to last longer than aftermarket. I have a Haynes manual that I don't really use but it does pretty well cover the process for R&R the heads on the 2.2. The torque sequence for the head bolts is correct in the Haynes manual. The factory service manual makes it seem more complicated since its layout is less user friendly. Link to comment Share on other sites More sharing options...
ThosL Posted November 21, 2016 Share Posted November 21, 2016 On 11/19/2016 at 7:43 PM, grossgary said: the fixes in a bottle *might* limp the car along for some unknown amount of time with severe downsides mentioned by caboob. they're like band aids - they're not long term, reliable solutions...if they help at all, they are going to come undone at some point in the future. It makes sense - ICE's are high temperature, pressures and cycling - 1,000+ degrees, 200 psi - roughly equivalent to woman in 1,000+ degree high heels stepping on your face. this isn't a simple, benign fluid loss situation, and it's almost comical to think it's an idea with excellent success rates. are they worth a shot in some situations? maybe in a rust rotted north east special with no chance of living more than 6 months. are they worth a shot in a financially desitute situation....i doubt it. a financially struggling person, IMO, needs to start making great long term financial decisions and quit thinking short term, and a solid car that can last another few years reliably is better than limping along, getting stranded again in 6 months, and needing some other cheap craigslist special that's going to cost more to maintain/fix repair than they can afford as well. there is a specific Subaru engine that responds well, in certain situations, to a Subaru Coolant Conditioner - that's a very specific engine, and even a very specific failure mode of that engine. It is by no means applicable to any other engines or failures modes. that boils down to physics and facts - not opinions. yours is not one of those engines nor one of those failure modes. you can include links to "readings" you find and we can address those more specifically though i imagine you're talking about the Subaru Coolant Conditioner or Blue Devil. No doubt some of the laws of chemistry and physics are against the head gasket fix solutions in a bottle, but based on apparently unbiased reports the stuff does work sometimes. Just check out all the Amazon reviews. But there are lots of people who don't follow directions too. Link to comment Share on other sites More sharing options...
idosubaru Posted November 21, 2016 Share Posted November 21, 2016 (edited) That's a good pint. Read the Amazon reviews. Probably a great central location for hearing success stories. I get that sometimes it works. Read those reviews with the following in mind. It's not long term high percentage, has risks and may lessen the vehicles value should something go wrong. plenty of the reviews are probably for simple leaks, not necessarily combustion chamber breeches. Just like Phase II external EJ leaks, that's a different story, those are easy. And nonSubarus may seal easier = apples and potatos. also a lot of those reviews are people saying it's fixed and then not long after posting they're probably right back at it again. I can literally find dozens or hundreds of "XYZ fixed my head gasket" then later "oh wait no it didn't" posts on Subaru forums, see it often- people think it's fixed and it's not. Just saw one yesterday. Those same people review on Amazon and don't follow up with "no it didn't" I doubt most people doing that stuff are concerned with 100,000 mile 5 year reliability. How many reports like that do we have - many years and miles? Many are limping basket cases along on pocket change. If that's your goal - sure try it, I get it, I was in college paying my way through once too. Agreed. Sifting through reviews looking for similar situations vehicles and symptoms would be a good check. Edited November 21, 2016 by grossgary Link to comment Share on other sites More sharing options...
ThosL Posted November 22, 2016 Share Posted November 22, 2016 I first bought the Subaru "conditioner" this time around. Still some bubbles, no overheating, then the BD pour and go product, still bubbles; could be air pocket not sure now; doesn't overheat. Link to comment Share on other sites More sharing options...
Sundancer268 Posted November 22, 2016 Share Posted November 22, 2016 Check out this WEB page, Most of it is on the 2.5 but the 2.2 is similar. Link to comment Share on other sites More sharing options...
Mindburn Posted November 22, 2016 Author Share Posted November 22, 2016 Im convinced to not get the crap in a bottle. So I took the car out for a drive after it sat for two years. Drove it 70-80 on the highway for 10 miles. No overheating, but the temp gauge climbed up and then dropped back to normal a few times. Im guessing the head gasket might still be on its way to death, but its interesting how the car is essentially driveable. Either way, it sounds minor? Link to comment Share on other sites More sharing options...
idosubaru Posted November 22, 2016 Share Posted November 22, 2016 A confirmed diagnosis would be good. Who knows what could be possible on a car that sat for two years. Keep an eye on: 1. coolant level/leaks/too much air 2. fans 3. if the radiator might be clogged - I think this is usually repeatable - like it's going to overheat more when it's hot out because the rad can't throw away enough heat, but works fine in cold 4. thermostat is flakey - could it be rusty from sitting? It sat where - in a frigid, muddy, rodent infested hedge row or a pristine heated show room garage? Link to comment Share on other sites More sharing options...
DaveT Posted November 22, 2016 Share Posted November 22, 2016 That is typical early signs of headgasket tiny leak. You may back able to drive it for 6 days, or 6 months before it gets worse. Watch the coolant level and air in the upper hose like a hawk. Before every drive. It may even vary a bit before it goes bad quickly. Every over normal temperature event accelerates the failure. Link to comment Share on other sites More sharing options...
ThosL Posted November 27, 2016 Share Posted November 27, 2016 I drove my 1997 2.5 yesterday without any problems and air bubbles stopped after using the Subaru conditioner and Blue Devil pour and go. Though bubble rate was not bad and no overheating. Link to comment Share on other sites More sharing options...
