freekraz Posted November 20, 2016 Share Posted November 20, 2016 Hello all, I've had a power steering leak in my '01 Legacy base model sedan for about a month. I have to put ATF into the reservoir every 3-4 days. I can't see any leaks from the pump when the engine is running. I have put the car up on ramps and watched from underneath, also can't see any active leaks. The fluid seems to be accumulating at the middle of the steering rack, where there's a small plate that mounts with four bolts and connects the engine subframe and another structural member. Took the plate out. Still can't see the leak. Any thoughts or suggestions? Steering seems to be OK when the fluid level is full, but there's an occasional grinding feeling in the steering wheel when returning from lock to center -- air bubbles in the system? Thanks in advance for any help. Jeff in Boston Link to comment Share on other sites More sharing options...
golucky66 Posted November 20, 2016 Share Posted November 20, 2016 Is there any fluid in the boot that covers the inner tie rods? Sometimes those seals leak and allow fluid to get into the boot. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 20, 2016 Share Posted November 20, 2016 Probably coming from one of the lines where it runs across the back of the rack, or from a fitting where the lines attach to the spool housing. Most steering rack leaks end up running toward the center of the lower crossmember and drip down the center. Follow the lines and you'll find it. Link to comment Share on other sites More sharing options...
forester2002s Posted November 20, 2016 Share Posted November 20, 2016 It's probably leaking when you're driving, so the oil-drops get blown away. Try parking with the engine running, with a piece of cardboard underneath. Maybe the leak will show up. Link to comment Share on other sites More sharing options...
