High beams go on = Fog lights go out?
EDIT: Turns out it's normal behavior and not a glitch. Thanks!
1997 Subaru Legacy Outback wagon. AT.
I've recently installed LEDs for the turn signals and headlamps. Fog lamps are still stock lights. Whenever I engage the high beams the fog lamps go out and then immediately turn back on when I disengage the high beams.
Is this normal behavior or pathological?
Edited by bstone
The first car I've ever seen to do this was my bosses '89 Ford Escort GT after he bought it new. I remember him saying he would like to re-route the wiring going to the relay from the park lamps so they would stay on all the time.
The fog lamps on factory cars and basically useless. I mean, they shine about 3 feet in front of the car. I thought fog lights were supposed to be amber instead of clear anyway before they were effective?
What I find odd is how come you can drive down the road with cargo lamp on. Looks to me like that light should not operate unless the parking brake is applied. Wouldn't that make sense?
it makes more sense that the roof mounted lights that came on Bajas from the factory that only operated with the braking brake applied. That make no sense at all!
I know this is against the law and everything but on two of my cars, my Fiat Spider and my Trabant 601, I've got my auxiliary lamps wired so that when I flip my high beams on, the auxiliary lights kick on for extra light. In other words the relay get's their power from one of the high beams. They are rather bright so I couldn't run them against on going traffic anyway.
I can't remember with the Yugo. I think I have the relay get's it's power from the park lamps. It's been out of commission for the past couple of years in need of new wheel bearings and tie rod ends. Just have not gotten around to fixing it. But like the Subaru, I have them aimed a bit lower so they just provide a bit of extra light.
Damn you got some ugly cars lol
Yeah, it is USDM regulation. 4 forward facing lights are allowed while low beams are lit. On high beam, only 2 forward facing lights are allowed... You can most likely get away with it, many do but you could get a ticket
Some older 60"s cars came from the factory with 4 headlights that worked on high beam and only 2 worked on low beam'
Yup, and some of those cars don't have seatbelts, dual reservoire master cylinders or other current regulations.. A LOT has changed in 40+ years. Headlight height wasn't even regulated then like it is now..
Yep, 1968 seemed to be the transition year for safety and emissions. The differences between 1967 and 1968 was a collapsible steering column, dual master cylinder, seat belts, PCV valve, weird timing ignition advance system based on coolant temperature among other things.
