Lynne Posted November 27, 2016 Share Posted November 27, 2016 I have a 2002 Impreza, 80,000 miles. The problem occurs when I make right turns only and not all the time, mostly on sharp turns. The noise happens after I make the turn when the steering wheel is returning to normal position. The noise is a somewhat grinding noise but I also feel a vibration at the same time. Link to comment Share on other sites More sharing options...
DaveT Posted November 27, 2016 Share Posted November 27, 2016 Could be wheel bearing or cv joint. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 27, 2016 Share Posted November 27, 2016 (edited) strut bearing? If you can duplicate the noise at low speed, maybe have a helper maneuver the car while you pace it and listen. there are enough possibilities that you likely need a pro to help diagnose this. Edited November 27, 2016 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
