more loyale problems.
Took my car back to my mechanic and he said that he thought the lack of power could have been an o2 sensor or a clogged cat but i changed both and its still doing it. Ive noticed its fine for the first few pulls in the morning when i first drive it , but as it warms up then it turns gutless... any ideas? I feel like ive tried everything and now its just starting to make me angry.
Thanks an advance.
-Tanner
93 loyale 4wd 5 speed
Hmmm... not much left if everything has been tried. :lol:
running poorly is possible from many things. how about:
Poor air flow
poor spark
poor compression
pcv clogged
Any CEL codes ?
Timing off
Poor air flow
poor spark
poor compression
pcv clogged
Any CEL codes ?
Timing off
Lots of things might do that. CTS?
Did you replace / check both catalytic s?
Although, I can't day I've seen one change over temperature - if it's blocked, it should be blocked.
But almost anything electric, / electronic can developed failure modes sensitive to heat / temperature. This means anything in the ignition circuits, engine control system, etc is suspect.
T in a fuel pressure gauge, so it can be viewed while the malfunction happens.
