Jman1991 Posted December 11, 2016 Share Posted December 11, 2016 I recently gutted the catalytic converter on my Loyale through the hole where the O2 sensor threads into caty, and then welded the hole shut. I'm wondering Will this cause any problems with the computer on my Suby? Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2016 Share Posted December 11, 2016 Well how did it run, you probably already took it for a spin right? ! In general yes the ECU uses that to adjust the air fuel ratio. Without it it'll presumably run rich and get poor mileage. I'm not sure if this actually would happen in this case but too much fuel washes the oil off the cylilnder walls, dilutes the oil. But you may also need to verify which engine/vehicle you're talking about. Link to comment Share on other sites More sharing options...
Jman1991 Posted December 11, 2016 Author Share Posted December 11, 2016 its a 1993 Loyale 4 wheel drive wagon. it seems to be running fine so far. it has more power. however I might try to find a decent caty at the scrap yard to replace the one i just gutted. it seems to me like it was designed to have an O2 sensor for a reason. so even though there are no noticeable problems from removing it, i just don't feel great about it. Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2016 Share Posted December 11, 2016 (edited) my understanding is the engine runs without the O2 when it's first started until the engine is warmed up. once it reaches a certain temperature then it uses the O2 sensor for feedback and adjusting air-fuel ratio. ; without the O2 sensor you're just stuck in that "pre-warm up" mode and probably running rich. given you have a fuel injected 93 loyale yeah I think you would be better off with one. though i've definitely driven around with oxygen sensors before and it's not a problem as a makeshift or temporary situaion, i'm not sure what long term would look like. in later lie 1995-2004 engines with a rear Oxygen sensor, those aren't used by the ECU and can be compeltely removed without any issues at all because the ECU doesn't even use them. they're only used to trigger a CEL, not for drivability. so you can ignore those, never replace them, remove them, and it doesn't matter for drivability. but that's different than yours - it's actually used for the air-fuel ratio. Edited December 11, 2016 by grossgary Link to comment Share on other sites More sharing options...
Jman1991 Posted December 11, 2016 Author Share Posted December 11, 2016 thank you for the info "elite master of subaru" so it seems like by what you are saying it would be better to run the vehicle with the O2 sensor but you Said "I think you would be better of without one" I'm a bit confused on this... Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2016 Share Posted December 11, 2016 d "I think you would be better of without one" Right! Edit - I meant "with one". that engine probably needs that sensor to deliver optimal fuel mileage. "elite...." is a randomly generated title by the board so don't assume much from it. Link to comment Share on other sites More sharing options...
idosubaru Posted December 11, 2016 Share Posted December 11, 2016 d "I think you would be better of without one" Right! Edit - I meant "with one". that engine probably needs that sensor to deliver optimal fuel mileage. "elite...." is a generated title by the board so don't assume much from it. Link to comment Share on other sites More sharing options...
Jman1991 Posted December 11, 2016 Author Share Posted December 11, 2016 okay haha it is an extreme title lol Thank you I appreciate the advice very much! Link to comment Share on other sites More sharing options...
dfoyl Posted December 12, 2016 Share Posted December 12, 2016 Gary is just being modest, he is a Elite Master of Subaru Your impression of more power is probably valid (somewhat), but the downside is longer-term damage caused by running rich and environmental damage by not running a cat while using unleaded fuel. Link to comment Share on other sites More sharing options...
Jman1991 Posted December 12, 2016 Author Share Posted December 12, 2016 yeah it's a blessing that you guys on here have so much knowledge and share it I just ordered a brand new caty and 02 sensor! Link to comment Share on other sites More sharing options...
DaveT Posted December 12, 2016 Share Posted December 12, 2016 Yes, you want the O2 sensor, as written above. Link to comment Share on other sites More sharing options...
