Stiff legacy Posted December 11, 2016 Share Posted December 11, 2016 Just joined,my 1999 legacy check engine light on, misfire on all 4 cylinders, bad 2nd bank o2, new knock sensor, newish plug and wires and coil and maf sensor, all on a newish 2.5 motor from Midwest motors, motor ran great then sputtered for a second and quit, drove around town and did it again for a second, then all of a sudden no power at all then died, wouldn't start for about 10 minutes then started and ran horrible. Also I did new subaru timing belt tensioner all you are supposed too do about 6 months ago, don't believe I skipped a tooth, I have had it happen before, I didn't have the timing belt guide on that time and an old tensioner, sorry so long just trying to put as much info as I can, any ideas would be great Link to comment Share on other sites More sharing options...
Rooster2 Posted December 11, 2016 Share Posted December 11, 2016 fuel pump or fuel filter?? Link to comment Share on other sites More sharing options...
Stiff legacy Posted December 11, 2016 Author Share Posted December 11, 2016 Thanks, thats what I thought, I have never replaced the fuel filter Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 12, 2016 Share Posted December 12, 2016 scan the ECU and post the code(s) parts store or consider getting am ELM327 BT device to use with smartphone. Link to comment Share on other sites More sharing options...
1997reduxe Posted December 16, 2016 Share Posted December 16, 2016 would that device work on a 95? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 16, 2016 Share Posted December 16, 2016 some 95s are OBD II - it's designed for that protocol. Should be an emissions sticker/label in the engine compartment - maybe underside of the hood? Link to comment Share on other sites More sharing options...
