BratWarrior Posted December 14, 2016 Share Posted December 14, 2016 Can't seem to find an answer. I'm getting things in order for a rear disc swap on my '84 BRAT. I know that I need 4WD hubs. Are the ea81 front 4WD hubs the same as the ea82 rear 4WD hubs? Link to comment Share on other sites More sharing options...
Numbchux Posted December 14, 2016 Share Posted December 14, 2016 (edited) No. Other than the basic concept, all the dimensions that matter are different, specifically that fronts are 30 spline, rears are 27. Edited December 14, 2016 by Numbchux Link to comment Share on other sites More sharing options...
andrsn Posted December 14, 2016 Share Posted December 14, 2016 This is the best tutorial I've seen, its really clear. I'm in the process of doing the same. http://offroadingsubarus.com/rear-disc-conversion-on-ea81-ea82s/ You should not need new hubs. You just need backing/mounting plates, calipers, pads, rotors and hose. I believe any Subi with the funky 4 bolt wheel stud pattern with rear discs should work, the only caveat is the donor car and your car need to match regarding FWD vs. 4WD. Someone correct me if I'm off on that... Link to comment Share on other sites More sharing options...
Numbchux Posted December 14, 2016 Share Posted December 14, 2016 (edited) This is the best tutorial I've seen, its really clear. I'm in the process of doing the same. http://offroadingsubarus.com/rear-disc-conversion-on-ea81-ea82s/ You should not need new hubs. You just need backing/mounting plates, calipers, pads, rotors and hose. I believe any Subi with the funky 4 bolt wheel stud pattern with rear discs should work, the only caveat is the donor car and your car need to match regarding FWD vs. 4WD. Someone correct me if I'm off on that... Yes, Hubs are different between disc and drum (drum cars do not even have separate hubs). In that write-up, the hub and rotor are bolted together, but there are 2 pieces there, and you will need both. Edited December 14, 2016 by Numbchux Link to comment Share on other sites More sharing options...
andrsn Posted December 14, 2016 Share Posted December 14, 2016 Yes, Hubs are different between disc and drum (drum cars do not even have separate hubs). In that write-up, the hub and rotor are bolted together, but there are 2 pieces there, and you will need both. You are correct, thanks for pointing that out. Link to comment Share on other sites More sharing options...
BratWarrior Posted December 15, 2016 Author Share Posted December 15, 2016 Thank you!!! There are differences between front and rear 4WD hubs. Got it! Now to get that project started... Link to comment Share on other sites More sharing options...
