michael_robert134 Posted December 21, 2016 Share Posted December 21, 2016 Found a 1987 gl turbo wagon 5 speed manual was wanting to know what to look for to see if its a good deal and what to be worries about. Link to comment Share on other sites More sharing options...
DaveT Posted December 21, 2016 Share Posted December 21, 2016 Entire cooling system. Was it ever overheated while low on coolant? [causes failing head gaskets] Headgaskets replaced? When were the timing belts changed? Search this forum for turbo threads. Care history? Was it left stock, or modified? Link to comment Share on other sites More sharing options...
Roger87ea82t Posted December 21, 2016 Share Posted December 21, 2016 The turbos have a tendency to crack the heads between the valves if they are run low on coolant and over heated. Make sure it is not loosing any coolant or you may have some relatively expensive repairs to fix. Roger Link to comment Share on other sites More sharing options...
