December 21, 20169 yr My first engine swap and I really could use someone's input ,ideas , an ld answer some questions
December 21, 20169 yr A little more specifics would help. Lots of people on here have probably dealt with similar things.
December 22, 20169 yr Hi, Welcome to the USMB. As noted above we need more info, but I'd HIGHLY recommend you spend some more time Searching, Reading, and Googling. RS25.com and NASIOC.com (they take no prisoners, so put on your big boy pants) probably have 2-2000 swaps detailing what you're doing. READ THE STICKIES @ the top of each forum - they are your new bible. :-) And remember, it'll likely cost twice as much and take four times as long to do the swap as you planned. GL, Td Edited December 22, 20169 yr by wtdash
December 22, 20169 yr Author I've got this 09 legacy gt with a blown up turbo I want to rebuild the turbo clean up everything that needs to be and swap the motor trans and whatever else I can onto my 95 impreza wagon and I really just am looking for tips and pointers from anyon that has done this before I know I can do it it's just a little overwhelming you know ?
December 22, 20169 yr Author My BIGGEST concern about the whole thing is the wiring harness/ecu so if someone could give giv me a little guidance as to how to go about that that would be EXTREMELY helpful
December 22, 20169 yr Is the '09 Totalled/crashed/etc? Otherwise, fix the turbo, sell it and your '95 and buy a clean WRX. You'll be FAR ahead of doing a swap. Td
December 22, 20169 yr It's a big leap between those years. 14 year difference so yes, you are looking at a minimum of swapping over the engine, exhaust manifold, engine wiring, ecu and maybe gauges. Not sure even if the bolt patterns ever changed in that span so make sure the 09 engine can bolt up to the 95 transmission and the correct flex plate or flywheel is in place to put the two together. The 1.8 or 2.2 flex plate is smaller diameter than 2.5s. As always, swaps like this will eat up far more time and money than ever anticipated. Make sure you don't depend on either vehicle for transportation and that you have the time, understanding and money to see it through.
December 22, 20169 yr 2009 Lego turbo might be can bus. If it is, your swap is impossible. You would need a non can bus wiring harness, ecu and intake. On top of that. Blown turbos often end up with blown engines due to metal in oil from turbo. Spend $800 on an ej20g. Work through the minor differences and sell your Lego stuff.. Or buy a wrx.
December 22, 20169 yr The 05-09 legacys are canbus, and have the immobilizer system. Your options are to find an 04 sti of forester xt wiring system and ecu, only those two will work easily because they aren't not canbus or immobilizer equipped, or go with a standalone.
