rds21 Posted December 27, 2016 Share Posted December 27, 2016 (edited) Hi All, Apologies in advance if this is a long post, however I want to give you all the details before you give me your opinion. I have a 2015 Crosstrek with 30,000 miles on it, and I'm trying to somewhat keep up with the maintenance recommendations so I had the front & rear differential fluids changed at a local shop. I did recently have the oil changed at the dealership, but the 30k service package was $800+ & 4 hours (had to pass). Here we are 15 days later I went on my first "trip" for the holidays (200 miles each way) and the AT OIL TEMP light comes on an hour into the drive! I pull over per the manual, idle until it cools/light out....every 45 minutes. At one of the stops I notice the coolant reservoir is basically empty and purchase the best 50/50 mix possible just to get it to the MIN line as I want to only use Subaru super blue coolant, but I won't be able to get that for a few days. Made it to the in-laws just fine and convinced myself it was all due to the low coolant. An hour into my trip back home BAM, AT OIL TEMP is back. First stop I let it idle and cool but it SMELLS HOT. This is my first new car; previously I had a 1999 supercharged Buick regal GS and I haven't smelled this smell since I had that 16 year old car going on a 100 degree day. Unfortunately it was only 20 degrees in Chicago when this happened another 4 times. Researching a bit more it's apparent that my engine light is related to transmission fluid temperature. The people at the local shop did mention they had issues filling because the fluid was thick and they didn't have a gravity pump, and now I'm connecting the dots. I'm assuming they did not completely fill the differentials and the first decent trip I took got the fluid warm & low enough to strain the transmission??? Is there any serious damage that could have occurred? Should I have any other fluids changed/parts inspected since I suspect very high heat built up somewhere? How hard do I need to crush this local shop? I was so excited to have a Subaru and want to nip this in the butt while it's under warranty and really appreciate any input you have. Edited December 27, 2016 by rds21 2 Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2016 Share Posted December 27, 2016 So far all the obvious and immediate steps are missing: 1. Check the ATF fluid level 2. Check the front diff fluid level 3. Check the radiator coolant level, note, and refill. The overflow tank is nearly pointless in an emergency situation. 4. Read the check engine light. Advance Auto and many chains and stores read them for free. You said "engine light" but you never mentioned when the engine light is coming on or any details about it. I don't think the shop is in the equation until the basic info above is known and a preliminary diagnosis is known. I would have done the first two immediately the first time the light blinked - takes like 1 minute. It may be unfilled, they may have drained one fluid but added new fluid to the wrong component. (Drained the ATF thinking it was the front diff). Or something completely unrelated. Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2016 Share Posted December 27, 2016 I have no idea how badly this thing was overheated or run low on fluid or if it was at all. So the following is by no means a diagnosis for this specific engine so much as a general answer to your question whether overheating affects things. More than likely yours incurred a minor event and no big deal. But we literally know nothing quantitatively significant to say anything meaningful either. Heat is orders of magnitude more significant than all the benign oil change questions people obsess over. So let's be clear. Overheating is atrocious for mechanical systems, it is the main contributor of heat, wear, degradation and catastrophic failures. Never overheat a Subaru engine short block component and they're nearly guaranteed to make 300,000 miles. Running low on fluid essentially results in localized overheating. initial compromising events are easily absorbed and if they cause issue many of them are initially asptomatic but lead to issue later due to materials fatiguing instigated during the compromising event. The only diagnosis option you might have this early on is a UOA and ATF analysis from a place like black stone labs. It's at least cheap and easy if you're game and may give you piece of mind. Link to comment Share on other sites More sharing options...
