Bratastick Posted January 3, 2017 Share Posted January 3, 2017 Do you have to remove the cross member in order to remove the fuel tank. I've got it all loose but there's just not much room to wiggle it out. Link to comment Share on other sites More sharing options...
TomRhere Posted January 3, 2017 Share Posted January 3, 2017 You need to lower the Mustache bar that holds the back of the rear diff in place. I usually just remove the nuts at both ends and use a small floor-jack to lower the diff. Link to comment Share on other sites More sharing options...
Bratastick Posted January 3, 2017 Author Share Posted January 3, 2017 You need to lower the Mustache bar that holds the back of the rear diff in place. I usually just remove the nuts at both ends and use a small floor-jack to lower the diff. Thanks. It looked like that to me but the manual didn't say anything about it, but couldn't tell if the instructions included the 4WD models or not. With all the hoses loose this thing is stinking up my whole house with bad gas smell. Link to comment Share on other sites More sharing options...
