FatCatDoS Posted January 5, 2017 Share Posted January 5, 2017 Resealing oil pump. I got the Mickey Mouse and the large oring on just fine but the shaft seal doesn't want to go all the way into the bottom of the seat. Is this normal or do I need to find a way to seat it in all the way? Looks like it seals around the shaft. But I'm afraid it's not in as far as it needs to be. Thanks for reading. Link to comment Share on other sites More sharing options...
DaveT Posted January 5, 2017 Share Posted January 5, 2017 The ones I've resealed, the seal face is pretty close to flush with the housing. I do know that some seals are made in different thicknesses, but it's hard to measure that now... Link to comment Share on other sites More sharing options...
FatCatDoS Posted January 5, 2017 Author Share Posted January 5, 2017 It was a genuine Subaru seal. If that matters. Link to comment Share on other sites More sharing options...
DaveT Posted January 5, 2017 Share Posted January 5, 2017 I would think one of those would go in flush. Maybe try to look in through the hole, to be sure it hasn't bottomed? Link to comment Share on other sites More sharing options...
Dee2 Posted January 5, 2017 Share Posted January 5, 2017 Here's a couple sets of photos which may show what you need.http://www.dirally.com/forums/showthread.php?2726-ea82-Oil-Pump-R-amp-Rhttp://www.ultimatesubaru.org/forum/topic/134867-1984-gl-18-oil-pump-rebuild-service/?do=findComment&comment=1135309 Link to comment Share on other sites More sharing options...
FatCatDoS Posted January 5, 2017 Author Share Posted January 5, 2017 http://imgur.com/y2RV0CJ That's what I'm working with. Looks flush with the upper part of the housing. But just doesn't seat into the bottom. Much like the cam seals I just did except those are supposed to sit flush as to mot block the oil passages. Link to comment Share on other sites More sharing options...
BEECHBM69 Posted January 6, 2017 Share Posted January 6, 2017 http://imgur.com/y2RV0CJ That's what I'm working with. Looks flush with the upper part of the housing. But just doesn't seat into the bottom. Much like the cam seals I just did except those are supposed to sit flush as to mot block the oil passages. I just did mine and that's what it looked like when I was done. Pulley went back on with no issues. Dan 1 Link to comment Share on other sites More sharing options...
