EA 82 Temp Sensor Controls?
That is just a thermo switch for the fan.
The ECU uses a sensor, CTS mounted on the housing just below the thermostat on the intake manifold. It has 2 wires. The single wire one is only for the temp gauge. If the CTS is flaky, the idle speed.is usually messed up, as in high idle when up to temp, or no high idle when cold.
