Ej25_Osport Posted January 10, 2017 Share Posted January 10, 2017 (edited) I just bought a 2008 Outback Sport for $1603. I work at a dealership and I took this car in has a trade in. one owner 200k but the owner was a travel nurse (Greg Focker) LOL. The car has 200k but the engine was replaced with a EJ25 with only 30 K on it. Problems- Loud Roaring sound, sounds like I have a hole in the exhaust. Mechanic said it could be the wheel bearings but he is not a Subaru Mechanic. It doesn't shake or steer to the left or right. TPS stays on not sure why. When you come to a stop, it revs to 3k then goes back to normal. Difficult to change gears it feels like the rpms drop really low every time i push the clutch in, IDK And I have to replace the AC Compressor Other than that Very nice car.. any thoughts and this is my first Subaru. Edited January 10, 2017 by Ej25_Osport Link to comment Share on other sites More sharing options...
lmdew Posted January 10, 2017 Share Posted January 10, 2017 Great Deal! Yes loud roaring sound can be wheel bearings. There may be no free play in the wheel but they can still be bad. Check the hub after a trip and see if one is hotter than the rest. If you pull the hub you can usually feel the roughness in the bearing when turning it by hand. The neutral switch if most likely out on the trans. The computer does not know when the clutch is in or out. Easy to check. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 10, 2017 Share Posted January 10, 2017 scan for codes. Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 10, 2017 Author Share Posted January 10, 2017 Thank you so much for the response!! Will check for codes today Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 10, 2017 Share Posted January 10, 2017 what's wrong with the a/c comp? many times, Subaru owners replace a coupla o-rings, maybe the schrader valves, recharge the system to the amount listed on the label under-hood and have no problems after that. quite common for the suction and discharge hose connections to need o-rings. occasionally, the clutch needs to be adjusted or a bearing goes bad. Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 10, 2017 Author Share Posted January 10, 2017 No codes , but I do have like knots on the outside of the tires Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 10, 2017 Author Share Posted January 10, 2017 Far as the ac compressor/ it's rusted with no belt on it Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 10, 2017 Author Share Posted January 10, 2017 Ok got it looked at today and This is what they told me lol Left front wheel hub/bearing Ac compressor and belt Front rear rotors warped Blower motor. I think I bit more than I could chew lol What do you guys think? Link to comment Share on other sites More sharing options...
lmdew Posted January 11, 2017 Share Posted January 11, 2017 All of that is easy stuff. Just get replacement parts and bolt them on. www.car-part.com Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 11, 2017 Share Posted January 11, 2017 rotors may be OK - read about 'uneven pad deposits' - even if they need replacing, as said fairly easy and not crazy expensive parts. I'd get Centric rotors from RockAuto or maybe amazon. 2008 should have HBA bearing - Timken from RockAuto would be my choice I think. if the a/c system has not sat exposed to the atmosphere, get a junkyard compressor, 2 new o-rings and schrader valves inserts, 22 or w'ever ozs of refrigerant and fix it. blower motor? dunno how hard to swap out, might be fiddly but likely not difficult. new cabin air filter while you're there. you might find DIY threads and youtube videos for most of that work. Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 11, 2017 Author Share Posted January 11, 2017 I know were my tax refund is going lol, someone told me that my EJ25 is the sti motor without the turbo is that true? Link to comment Share on other sites More sharing options...
Ej25_Osport Posted January 14, 2017 Author Share Posted January 14, 2017 Any recommendations on installing a turbo on this engine? I use to own a SRT-4 and i want the sound back lol Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 14, 2017 Share Posted January 14, 2017 uneven length headers feeding the turbo is mostly what makes that distinctive sound. a full swap of engine, trans and rear diff would be best. ' Impractical ' to just add a turbo to an NA engine. you CAN make you car more fun to throw around the corners - weight reduction, stickier tires, heavier springs/antisway bars, etc. "it's more fun to drive a slow car fast than a fast car slow" 1 Link to comment Share on other sites More sharing options...
