rogerz Posted January 17, 2017 Share Posted January 17, 2017 2005 Outback about 100K. standard engine auto. When just sitting there I get around a half amp draw from the battery. pulled all fuses inside and engine compartment with an ammeter attached to monitor draw. NOthing. except back up lights showed slightly less draw. Any thoughts on usual problems with this car. best place to look for possible slight ground? Quote Link to comment Share on other sites More sharing options...
golucky66 Posted January 17, 2017 Share Posted January 17, 2017 Pull the fuses under the dash aswell to narrow down the location of the draw. Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 17, 2017 Share Posted January 17, 2017 Another possible path is through the main alternator output wire. Partially failed rectifiers can do things like that. Simple to check, just un bolt it. But it is live if the battery is connected, so pull the GND (-) side first. Quote Link to comment Share on other sites More sharing options...
Dj7291993 Posted January 18, 2017 Share Posted January 18, 2017 Make sure you've let the thing sit long enough for the computers to shut down. 30 mins should be long enough. Your back up lights shouldn't be drawing anything key off, but if that doesn't drop you down below 0.050A, then it's not your main issue. I'd agree with the alternator, try pulling the connector and the charge wire. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2017 Share Posted January 18, 2017 (edited) pulling the battery cable fully discharges all systems. Reconnecting via a multimeter causes a large ramp up draw for computers and electronics right? So maybe you're just seeing that initiliazation draw rather than nominal draw? Edited January 18, 2017 by grossgary Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 18, 2017 Share Posted January 18, 2017 Are there any custom installs or electrical work done? Phone charges, 12 volt recepticles, stereo, remote start, car alarm, DVD, lighting, custom HIDs, etc. Or any components not working correctly or intermittently? Any recent repairs before this stated? Those are common areas with issues. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 18, 2017 Share Posted January 18, 2017 if there's unswitched voltage going to the hatch, maybe chafed/shorting wires in the boot from body to hatch? 1 Quote Link to comment Share on other sites More sharing options...
