coastalsubie Posted January 20, 2017 Share Posted January 20, 2017 How hard to replace rear brakesm Brake shoes? Link to comment Share on other sites More sharing options...
ocei77 Posted January 20, 2017 Share Posted January 20, 2017 Not that hard, just not as easy as disc. Buy hardware kit. You may not need it, but it's better to have in case you do when all is apart and you can't go get it. The springs and the metal discs are what may be needed, Back off the adjusting screw so the pads are not pushed up against the drum. Have 2 m8x1.25 bolts about 2 in. long available. If the drum doesn't come right off, use the bolts in the threaded holes to push them off. If the drum is still hanging up as it comes off, back off the adjusting screw more. Get FSM from New Gen FAQ sticky. 2nd page under my name. Needle nose grip pliers are great for pulling the springs into place, unless you want to buy the tool to do it. O. Link to comment Share on other sites More sharing options...
