sirtokesalot Posted January 21, 2017 Share Posted January 21, 2017 will the power steering pump from a 2002 outback work on a 1998 outback? my parents have a 2002 parts car and ive noticed im losing power steering fluid and its pooling under the pump running down between the timing covers and out the bottom. yes i know about the oil pressure sensor but its not wet around that sensor it is wet under the power steering pump and my power steering fluid is very low. Link to comment Share on other sites More sharing options...
matt167 Posted January 21, 2017 Share Posted January 21, 2017 If it fits the mount and hoses, it will work. Subaru racks are all basically identical Link to comment Share on other sites More sharing options...
ocei77 Posted January 21, 2017 Share Posted January 21, 2017 Watch the fitting on the pump. Some have a different size. If necessary all you'd have to do is swap the line from the junction up to the pump. O. Link to comment Share on other sites More sharing options...
