alpop Posted January 23, 2017 Share Posted January 23, 2017 '99 Legacy AWD. If I have four tires and two are a little more worn than the other two (1/32nd inch), is it best to put them on the front or back? Seems like I remember that most of the time power goes to the front, and only goes to the rear when needed? So better tires on the front to even out the wear? Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 23, 2017 Share Posted January 23, 2017 Yes, better tires on the front. The front tires wear faster since they do the steering. Eventually they will even out. 1 Link to comment Share on other sites More sharing options...
forester2002s Posted January 23, 2017 Share Posted January 23, 2017 If the worn tires are already on the front, you may need a front-end alignment. Link to comment Share on other sites More sharing options...
alpop Posted January 23, 2017 Author Share Posted January 23, 2017 These are used snow tires I bought from someone else. Thanks for your input- Link to comment Share on other sites More sharing options...
idosubaru Posted January 23, 2017 Share Posted January 23, 2017 this: Yes, better tires on the front. The front tires wear faster since they do the steering. Eventually they will even out. Link to comment Share on other sites More sharing options...
Subabro Posted February 1, 2017 Share Posted February 1, 2017 Front tires are responsible for acceleration, braking and steering that's why they normally wear faster. Link to comment Share on other sites More sharing options...
keith3267 Posted February 3, 2017 Share Posted February 3, 2017 For such a small difference, put the better tires on the front. For vehicles that are not AWD, if you have a large difference, say 4/32" or greater, then the better tire go on the rear for safety reasons, even for FWD vehicles. On a AWD vehicle, any differences greater than 2/32", the tires must be replaced or the better tires shaved down to match. Link to comment Share on other sites More sharing options...
