Bratastick Posted January 31, 2017 Share Posted January 31, 2017 I can tell even before cutting open the tank that the baffle inside is only partially attached and is loose. Looks like it's missing a good bit of it's original heft, it has just rusted away. Guess that's what was on the bottom of the tank! Is it worth trying to re-make this once I get the tank open. May not be that difficult to do once I get it open. I'm going to cap off or remove all the misc. hoses going into the tank other than the supply, return and vent. Link to comment Share on other sites More sharing options...
skishop69 Posted January 31, 2017 Share Posted January 31, 2017 (edited) You need the baffle and the other lines. The baffle holds fuel in place around the pickup so that when the fuel level is low and you accelerate, corner or climb a hill, there is always fuel surrounding the pickup or you suck air and stall. Other lines? There are only the three. Edited January 31, 2017 by skishop69 Link to comment Share on other sites More sharing options...
Bratastick Posted January 31, 2017 Author Share Posted January 31, 2017 On 1/31/2017 at 3:42 PM, skishop69 said: You need the baffle and the other lines. The baffle holds fuel in place around the pickup so that when the fuel level is low and you accelerate, corner or climb a hill, there is always fuel surrounding the pickup or you suck air and stall. Other lines? There are only the three. There are two poking out of the side next to the filler neck. Link to comment Share on other sites More sharing options...
skishop69 Posted January 31, 2017 Share Posted January 31, 2017 Hmmmm.... I'll have to look at mine when I get home. The spare tank I have has no such lines. I would imagine one of them is a fill vent and you'd want that or else it will burp fuel while you're filling it and keep shutting off the filler nozzle. Link to comment Share on other sites More sharing options...
wagonist Posted January 31, 2017 Share Posted January 31, 2017 Don't remove the extra lines near the fuel tank. The 1/2" one is the fill vent so the air in your tank has somewhere to escape when refuelling. The other one is (eventually) connected to the charcoal canister in the engine bay. Link to comment Share on other sites More sharing options...
Bratastick Posted February 1, 2017 Author Share Posted February 1, 2017 I'm converting to a Weber so I really should only need the supply, return and air vent. The air vent is pretty good size and connects up to the filler neck. The other small ones I'm guessing have something to do with the emissions and the plastic tank in the back. Link to comment Share on other sites More sharing options...
