Ea82 radiator fan
Mines making all sorts of noises and sounds like the bearing went out...if they have bearings not sure. Sounds like when you try to spin a bad bearing to fast and it just squeaks. Any found a better solution to replace the one that's in there. Looks stock but not sure. Would like to replace it. Thanks in advanced.
Are you talking about the electric fan on the passenger side? Or the clutch fan on the front of the water pump?
Dan
  • Like 1
I have put few drops of oil on the shaft.  Did it two-three times and it started working again.
I guess you know that this fan does not work all the times?  It works when the engine gets too hot or when your AC is on.
Good luck,
Sam
