nitroman58 Posted February 5, 2017 Share Posted February 5, 2017 Over the summer, I bought a new set of tires for the Forester from Costco. Today, I went back for a tire rotation, and the guy in charge told me who ever put the tires back on the car cross threaded 2 of the lug nuts. They had to break the lugs to get the tires off. Apparently, they said that the technician may have put the lugs in the gun before starting the threading on the car. They said that they would reimburse me on the expense. What do you think this would wind up costing? Do you think it is worth going back to dealer for this? I am concerned the other lug nuts could have damage too. Thanks Link to comment Share on other sites More sharing options...
lostinthe202 Posted February 5, 2017 Share Posted February 5, 2017 I wouldn't bother going to the dealer. They had to get all the lugs off to rotate your tires, if there was more than two damaged, they would have told you so. FYI, it seems you've posted this twice, might want to delete the other one Will- Link to comment Share on other sites More sharing options...
whynot Posted March 2, 2017 Share Posted March 2, 2017 cost should not be too much. Front or rear? Mast cars the stud just gets knocked out and the new one back in. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 2, 2017 Share Posted March 2, 2017 (edited) Yup. Just let them make good on the mistake. They came forward with it rather than try to cover it up or claim that the studs sheared or were rusted etc. On these cars it's very straightforward. Let them replace the 2 studs and keep on driving. Any decent shop can do it for an hour or so labor and $5-10 for the two studs. Edited March 2, 2017 by AdventureSubaru Link to comment Share on other sites More sharing options...
dfoyl Posted March 2, 2017 Share Posted March 2, 2017 Just take off one lug nut at a time, inspect the thread, and replace before doing the next nut. Gives you peace of mind, and you really don't want to get a flat and not be able to remove the wheel... If you find any with "iffy" threads, mark the lugnut with a spot of paint or tape and run it back to Costco so they can fix them also. Link to comment Share on other sites More sharing options...
