The "new" CCR engine rebuilders?
It looks as though CCR has changed hands??
Does anyone know to what extent things have changed or restructured as far as management and/or experienced builders goes?
I currently have a JDM 2.0L SOHC (non-turbo) in my 2k OBW and its absolutely dreadful on power. I use my Subaru like a truck not a grocery-getter and this things not cutting it anymore. I'd like to drop a 2.5 back in when I can afford it.
Way back when I was on this forum a lot more, I remember CCR having lots of positive reviews and even EMILY chiming in a time or two to add some very knowledgeable advice and comments.
If I go this route I'd like to know CCR is still as reputable (if not more so) as they were before the restructure.
Edited by 211
  • Like 1
I don't know about CCR's restructuring, but I build all the engines for my shop personally. I can build one however you like and we are a lot closer than Colorado. Typically we build them using the newer heat treated turbo crankshafts and tri-metal race bearings, etc. There are other options besides a full rebuild also. Subaru themselves offers a reman short block assembly thats reasonable or we could source a used engine and just do piston rings, skirt knurling, etc. Hit us up on Facebook if you would like a quote:
https://m.facebook.com/superiorsoobie/
  • Like 3
I don't have FB but I'm interested in service of some sort.
What I have is a 2.0L SOHC and I want a 2.5 back. For core purposes is the 2.0 useless as a return core for a 2.5?
I would not need a core. We would just get you a used engine. I often just buy ones that came from front end collisions and have bent valves, etc. It's not a problem to swap out the valves if you are already doing head gaskets, rings, etc.
Or we could buy a reman short block from Subaru. They are about $2150. I have lots of extra heads no problem there.
If you want a custom build with heat treated crank and race bearings, etc then we could either buy new case halves from Subaru or I can have a used set reconditioned, etc.
You can also email me at:
rick@superiorsoobie.com
Or call the shop:
503-880-4084
Edited by GeneralDisorder
Totally different shop in a new location.
I use to take used 2.5 DOHC cores up the Rick and Emily at the old CCR.  I always enjoyed doing business with them over the years.
Great source of engines and information.
The new owner seems good, it's just not the same CCR.
I assume they are good, time will tell.
  • 4 years later...
Scott , I hope you mean EA81 and not EA82
Its your business of course but man it would hurt me if you stuck an OHC engine in there. If you do , go EJ not EA.
Best of luck with it. Enjoy !
No experience with CCR other than Shawn worked there once upon a time and yeah we played “Willy and the Poor Boys” until we wore the grooves down.
  • Like 1
