Steering wheel swap and Hvac switch
skybren
The steering wheel is a direct fit.
As for the HVAC, no its a lot more complicated. The L.L. Bean has an electronically controlled system whereas your standard sedan is all mechanical. In order to make it work, the entire heater box assembly has to be swapped over, a wiring harness made and run, plus the head unit. It also runs a more complex AC compressor which cannot be adapted easily.
