EA71 with Weber, Carb Fuel Adjustment?
Looking at the front of the car, the adjustment screw is pointed about 45degrees to the passenger side. Almost directly at the distributor. Screw it out to add more fuel. start in small infringements. Like 1/4-1/2 turn and continue until you're satisfied.
Ah okay. Thank for the replies. I haven't had a chance to go over and play with it yet, tomorrow I get to.
While it does starve for fuel on cold starts, I'm pretty sure its not as "powerful" as it used to be (or so to speak). And I noticed it after I had it adjusted so it would pass smog. I bet if we richen it up all will be better. I'll let you knowhow it turns out. Maybe I should make another quick vid so others can see...
  • 2 weeks later...
