3Pin Posted February 11, 2017 Share Posted February 11, 2017 Has 155k and is in decent shape. Looks like it needs HG work and possible a leaky power steering pump and some rear tires or bearings. Does anyone else know if there are any other good or bad issues with this series as this in new territory for me. Thanks in advance Quote Link to comment Share on other sites More sharing options...
rocketman Posted February 12, 2017 Share Posted February 12, 2017 I like the body style,but the big dawgs here are saying bad rod bearings,uncomfortable seats,bad window motors,and switch's,also carry less weight,and ordering parts can be a debaco. Quote Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted February 12, 2017 Share Posted February 12, 2017 Never had an issue ordering parts but rust is always a major issue and they all leak oil. The rust will make certain things like the calipers almost impossible to service and makes removing nuts and bolts a hassle or even dangerous. Keep everything lubricated under the car as best as you can. Quote Link to comment Share on other sites More sharing options...
rocketman Posted February 12, 2017 Share Posted February 12, 2017 Any comment on rod bearings? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 12, 2017 Share Posted February 12, 2017 (edited) It isn't the rod bearings. It's the 7mm oil pumps. Change it out to a 10mm. The rod bearings and even the rods themselves can be found in Subaru's turbocharged model engines where they do not have failure problems because those engines had 10mm pumps from the factory. GD Edited February 12, 2017 by GeneralDisorder 1 Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 12, 2017 Author Share Posted February 12, 2017 so ,when doing the hg work replace the 7mm pump to a 10mm even at 155k on the clock? Quote Link to comment Share on other sites More sharing options...
montana tom Posted February 12, 2017 Share Posted February 12, 2017 (edited) I use the 11 mm pump . Here is the item # 142251153734 on ebay . Brand new O.E. $138 delivered. Here's the # 131638875556 for the same thing with new bolts and both seals for $154 I buy from this company often, very reputable. Edited February 12, 2017 by montana tom Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 12, 2017 Author Share Posted February 12, 2017 cool thanks Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 12, 2017 Author Share Posted February 12, 2017 Yup, one electric window not working. One kinda sticky outside door handle and the interior finish doesn't hold up as well as my 00-04's. Not bad though, got it for $750. It will need two rear wheel bearings, head gaskets etc. But really clean outside and pretty clean inside. Quote Link to comment Share on other sites More sharing options...
montana tom Posted February 12, 2017 Share Posted February 12, 2017 Hey for that price you bet it was worth it. The 05's are the first year of " drive by wire" no cable from the pedal to throttle body , (stupid, IMO). There have been connection issues between the pedal assembly and computer. Unplug it at throttle pedal , inspect it well then use dielectric grease when plugging it back in. May help. Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 13, 2017 Author Share Posted February 13, 2017 So the right rear window will not lower or raise. Tried it from the front switch and the RR door switch. nothing. Is that a motor you think? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 13, 2017 Share Posted February 13, 2017 We are still working on determining the viability of using the 11mm pumps on non dual-AVCS engines. It may be too much flow. I'll have data soon to determine exactly which pump is best based on temp, viscosity, bearing clearances, pump size, and oil volume consuming devices (turbo chargers, intake/exhaust AVCS, AVLS, etc). Too big of a pump and you cause the bypass in the pump to open more often and it may be unable to flow enough volume to drop the pressure to a desirable level. We also want to know under what conditions the oil filter bypass valve will be bypassing. Science. For now the 10mm pump us the safest bet. It is used all the way up to 14 WRX's. GD 2 Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 13, 2017 Author Share Posted February 13, 2017 Thanks GD. I will work on the other issues for now and wait to hear on which oil pump I should use. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 15, 2017 Share Posted February 15, 2017 It isn't the rod bearings. It's the 7mm oil pumps. Change it out to a 10mm. The rod bearings and even the rods themselves can be found in Subaru's turbocharged model engines where they do not have failure problems because those engines had 10mm pumps from the factory. GD GD - which cars have the 7mm pump and what is the number for the 10mm pump? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 15, 2017 Share Posted February 15, 2017 Use parts.subaru.com and lookup a 2003 non turbo. It will be a 7. Then click on the "what this fits" tab and it will tell you all the models that called out a 7. Then lookup a 2006. That will have a 10 because it's an AVLS engine. GD 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 16, 2017 Share Posted February 16, 2017 it says; Subaru: 5 models, 178 variants between 2002 and 2006. OIL PUMP ASSEMBLY-ENGINE Part Number: 15010AA290 ; 15010AA260; 15010AA261; 15010AA262 so, I assume all non-turbo models in that range have those numbers stock and they are 7mm very interesting looks like the 10mm part number is; used in 7 models, 275 variants between 1991 and 2009. Part Number: 15010AA300 ; 15010AA103; 15010AA104; 15010AA105; 15010AA106; 15010AA107; 15010AA108; 15010AA109; 15010AA280 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 16, 2017 Share Posted February 16, 2017 There are multiple part numbers for the 10. Some didn't have the provision for the timing belt guide plate. There are 9's out there too. And 11's, and 12's (Japan). Some 10's are marked with a 10 like the 7 and 9 are marked. 11's are marked "78" and I believe the newer 10's are marked "76". GD 2 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 16, 2017 Share Posted February 16, 2017 There are multiple part numbers for the 10. Some didn't have the provision for the timing belt guide plate. There are 9's out there too. And 11's, and 12's (Japan). Some 10's are marked with a 10 like the 7 and 9 are marked. 11's are marked "78" and I believe the newer 10's are marked "76". GD good info - kinda confusing for us that don't handle this stuff regularly. found a coupla pics - here's the '78' (11 mm?) are these the same size as marked? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 16, 2017 Share Posted February 16, 2017 Yes those would be a 7 and 9. It is the thickness of the georotor in millimeters. GD 2 Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 17, 2017 Author Share Posted February 17, 2017 Holy smokes. Then which part number would I use for my 2005 2.5 10 mm replacement oil pump? I am not real clear, but want to make sure I and others moving forward are as well. Quote Link to comment Share on other sites More sharing options...
rocketman Posted February 17, 2017 Share Posted February 17, 2017 You have my attention! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 17, 2017 Share Posted February 17, 2017 (edited) last line of post 16 seems to be 10mm part numbers. you should ask gd to confirm, and, when you receive the part, measure the rotor thickness. Edited February 17, 2017 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
3Pin Posted February 20, 2017 Author Share Posted February 20, 2017 This is what i found: Part Number: 15010AA300 ; 15010AA103; 15010AA104; 15010AA105; 15010AA106; 15010AA107; 15010AA108; 15010AA109; 15010AA280 What it fits: Subaru Baja 2.5L TURBO MT 4WD T 2004, 2005, 2006 Subaru Baja 2.5L TURBO MT B PICK UP 2004, 2005, 2006 Subaru Baja 2.5L TURBO MT PICK UP 2004, 2005, 2006 Subaru Baja 2.5L TURBO S/S 4WD T 2004, 2005, 2006 Subaru Baja 2.5L TURBO S/S B PICK UP 2004, 2005, 2006 Subaru Baja 2.5L TURBO S/S PICK UP 2004, 2005, 2006 Subaru Forester 2.5L AT L 1998 Subaru Forester 2.5L AT S 1998 Subaru Forester 2.5L AT X 2006, 2007, 2008 Subaru Forester 2.5L AT XT Sports 2008 Subaru Forester 2.5L MANUAL Base Premium 1998 Subaru Forester 2.5L MANUAL L 1998 Subaru Forester 2.5L MANUAL Premium 1998 Subaru Forester 2.5L MANUAL S 1998 Subaru Forester 2.5L MANUAL X 2006, 2007, 2008 Subaru Forester 2.5L MANUAL XT Sports 2008 Subaru Forester 2.5L TURBO AT XT Sports 2004, 2005, 2006, 2007, 2008 Subaru Forester 2.5L TURBO MT XT Sports 2004, 2005, 2006, 2007, 2008 Subaru Impreza (205) 5MT 4WD GT Sedan 2002, 2003, 2004, 2005 Subaru Impreza (205) 5MT 4WD WRX Premium Wagon 2002, 2003, 2004, 2005 Subaru Impreza (205) 5MT 4WD WRX Sedan 2002, 2003, 2004, 2005 Subaru Impreza (205) 5MT 4WD WRX Wagon 2002, 2003, 2004, 2005 Subaru Impreza (205) AT 4WD GT Sedan 2002, 2003, 2004, 2005 Subaru Impreza (205) AT 4WD WRX Premium Wagon 2002, 2003, 2004, 2005 Subaru Impreza (205) AT 4WD WRX Sedan 2002, 2003, 2004, 2005 Subaru Impreza (205) AT 4WD WRX Wagon 2002, 2003, 2004, 2005 Subaru Impreza (257) 6MT 4WD STI Limited Sedan 2006 Subaru Impreza (257) 6MT 4WD STI Sedan 2004, 2005, 2006 Subaru Impreza 2.5L 5MT 4WD Outback Sport Wagon 2006 Subaru Impreza 2.5L 5MT 4WD Outback Wagon 2006, 2007 Subaru Impreza 2.5L 5MT 4WD Premium Sedan 2006 Subaru Impreza 2.5L 5MT 4WD Premium Wagon 2006 Subaru Impreza 2.5L 5MT 4WD Sedan 2006, 2007 Subaru Impreza 2.5L 5MT 4WD Wagon 2006, 2007 Subaru Impreza 2.5L AT 4WD Outback Sport Wagon 2006 Subaru Impreza 2.5L AT 4WD Outback Wagon 2006, 2007 Subaru Impreza 2.5L AT 4WD Premium Sedan 2006 Subaru Impreza 2.5L AT 4WD Premium Wagon 2006 Subaru Impreza 2.5L AT 4WD RS Coupe 1998 Subaru Impreza 2.5L AT 4WD Sedan 2006, 2007 Subaru Impreza 2.5L AT 4WD Wagon 2006, 2007 Subaru Impreza 2.5L MT 4WD RS Coupe 1998 Subaru Impreza 2.5L TURBO 5MT 4WD GT Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Premium Wagon 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX TR Sedan 2006 Subaru Impreza 2.5L TURBO 5MT 4WD WRX Wagon 2006 Subaru Impreza 2.5L TURBO 6MT 4WD STI Limited Sedan 2006 Subaru Impreza 2.5L TURBO 6MT 4WD STI Sedan 2004, 2005, 2006 Subaru Impreza 2.5L TURBO AT 4WD GT Sedan 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Premium Wagon 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Sedan 2006 Subaru Impreza 2.5L TURBO AT 4WD WRX Wagon 2006 Subaru Legacy 2. L GRADE : TURBO Sedan 1991, 1992 Subaru Legacy 2.5L 4AT 4WD Limited 2006, 2007 Subaru Legacy 2.5L 4AT 4WD Limited Wagon 2006, 2007 Subaru Legacy 2.5L 4AT 4WD SE Wagon 2006 Subaru Legacy 2.5L 4AT 4WD Sedan 2006, 2007 Subaru Legacy 2.5L 5MT 4WD Limited Wagon 2006, 2007 Subaru Legacy 2.5L 5MT 4WD SE Wagon 2006 Subaru Legacy 2.5L 5MT 4WD Sedan 2006, 2007 Subaru Legacy 2.5L AT 4WD GT Limited Sedan 1996, 1997, 1998, 1999 Subaru Legacy 2.5L AT 4WD GT Sedan 1996, 1997, 1998, 1999 Subaru Legacy 2.5L AT 4WD GT Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L AT 4WD Limited Touring Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L AT 4WD LSI Sedan 1996, 1997 Subaru Legacy 2.5L AT 4WD LSI Wagon 1996, 1997 Subaru Legacy 2.5L AT 4WD Outback Touring Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L AT 4WD SUS Sedan 1997, 1998, 1999 Subaru Legacy 2.5L MT 4WD GT Limited Sedan 1996, 1997, 1998, 1999 Subaru Legacy 2.5L MT 4WD GT Sedan 1996, 1997, 1998, 1999 Subaru Legacy 2.5L MT 4WD GT Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L MT 4WD Limited Touring Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L MT 4WD Outback Touring Wagon 1996, 1997, 1998, 1999 Subaru Legacy 2.5L TURBO 5AT 4WD GT Limited Sedan 2005, 2006, 2007, 2008, 2009 Subaru Legacy 2.5L TURBO 5AT 4WD GT Limited Wagon 2005, 2006, 2007 Subaru Legacy 2.5L TURBO 5AT 4WD GT Wagon 2005, 2006 Subaru Legacy 2.5L TURBO 5AT 4WD Limited Wagon 2005, 2006 Subaru Legacy 2.5L TURBO 5MT 4WD GT Limited Sedan 2005, 2006, 2007, 2008, 2009 Subaru Legacy 2.5L TURBO 5MT 4WD GT Limited Wagon 2005, 2006, 2007 Subaru Legacy 2.5L TURBO 5MT 4WD GT Wagon 2005, 2006 Subaru Legacy 2.5L TURBO 5MT 4WD Limited Wagon 2005, 2006 Subaru Legacy 2.5L TURBO 6MT 4WD GT Limited Sedan 2006, 2007, 2008, 2009 Subaru Legacy 2.5L TURBO MT 4WD BAJA-B PICK UP 2004, 2005, 2006 Subaru Legacy 2.5L TURBO S/S 4WD BAJA-B PICK UP 2004, 2005, 2006 Subaru Legacy 4. L GRADE : TURBO Sedan 1991, 1992, 1993, 1994 Subaru Legacy 4. L GRADE : TURBO WAGON 1992, 1993, 1994 Subaru Outback 2.5L 4AT Base 2006, 2007 Subaru Outback 2.5L 4AT Limited 2006, 2007 Subaru Outback 2.5L 5MT Base 2006, 2007 Subaru Outback 2.5L 5MT Limited 2006 Subaru Outback 2.5L TURBO 5AT XT 2005, 2006, 2007 Subaru Outback 2.5L TURBO 5AT XT Limited 2005, 2006, 2007, 2008, 2009 Subaru Outback 2.5L TURBO 5MT XT 2005, 2006, 2007 Subaru Outback 2.5L TURBO 5MT XT Limited 2005, 2006, 2007, 2008, 2009 Subaru Outback 3.0L 5AT L.L.Bean 2006 Subaru Outback 3.0L 5AT Limited 2006 Subaru Outback 3.0L 5AT R 2006 Subaru STI (257) 6MT 4WD Limited Sedan 2006 Subaru STI (257) 6MT 4WD SEDAN 2004, 2005, 2006 Subaru STI 2.5L TURBO 6MT 4WD Limited Sedan 2006, 2007 Subaru STI 2.5L TURBO 6MT 4WD SEDAN 2004, 2005, 2006, 2007 Subaru WRX (205) 5MT 4WD SEDAN 2002, 2003, 2004, 2005 Subaru WRX (205) 5MT 4WD WAGON 2002, 2003, 2004, 2005 Subaru WRX (205) AT 4WD SEDAN 2002, 2003, 2004, 2005 Subaru WRX (205) AT 4WD WAGON 2002, 2003, 2004, 2005 Subaru WRX 2.5L TURBO 5MT 4WD SEDAN 2006, 2007 Subaru WRX 2.5L TURBO 5MT 4WD TR SEDAN 2006, 2007 Subaru WRX 2.5L TURBO 5MT 4WD WAGON 2006, 2007 Subaru WRX 2.5L TURBO AT 4WD SEDAN 2006, 2007 Subaru WRX 2.5L TURBO AT 4WD WAGON 2006, 2007 Quote Link to comment Share on other sites More sharing options...
