ojito Posted February 14, 2017 Share Posted February 14, 2017 Which brats, if any, won't the EA81 or the EA81Turbo fit in. Any bell housing or wire harness or motor mount or exhaust manifold or distributor changes necessary? Was there any thing wrong with the EA81 since subaru only offered it from 83 to 84? Quote Link to comment Share on other sites More sharing options...
Naked Buell Posted February 14, 2017 Share Posted February 14, 2017 Any GL that offered the ea81T will fit the Brat. The problem is finding parts. You would be better to stay to the ea81 or to do a Ej swap. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted February 14, 2017 Share Posted February 14, 2017 The EA81 was offered from 1979 through 1994 internationally. It's pretty much the best pre-EJ engine Subaru made (some would say ever). USDM was 1980 through 1986 I believe... Quote Link to comment Share on other sites More sharing options...
ojito Posted February 14, 2017 Author Share Posted February 14, 2017 Ok.So there's a relatively low mileage 1800 engine from a 1986 brat GL for sale. Will that be an easy swap for my present 1600 in my 1980 brat GL? Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted February 14, 2017 Share Posted February 14, 2017 Yes but you will also need the transmission out of that brat or you need to find a 5 speed d/r Quote Link to comment Share on other sites More sharing options...
ojito Posted February 14, 2017 Author Share Posted February 14, 2017 Very good you guys...I can see the light at the end of the tunnel now. So I'm in the process of deciding on which used engine folks have the best price on there 1800. The only Leed I have now is from a place in Arizona (a 86 Gl with 13000 miles for $820 w/shipping).And 1800's were paired w/5 speed tyranny evidently so need to get that too. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 15, 2017 Share Posted February 15, 2017 (edited) Won't directly fit into an 80 without an 81 GL Brat engine cradle or modifications to the steering linkage. The 1800 wasn't offered in a first gen except the 81 GL Brat. As stated you will need a side starter bell housing transmission as well. The only 5 speed offered with the EA81 is a 2 wheel drive trans. You will need the 4 speed 4WD trans that matches or a 5 speed 4WD from and 85 to 89 but that also requires modifications to driveline, mounting, linkage, etc. It's not as simple as you think or have been led to believe. GD Edited February 15, 2017 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
