the goat Posted June 15, 2004 Share Posted June 15, 2004 i understand that many people purchase the pug wheels because of the 4 lug pattern but where i work i have noticed an old bmw 2002 with a 4 lug pattern rim and a honda civic with a 4 lug pattern rim. will these fit a subaru? just wondering. i thought most passenger cars were 5 lug. thanks for any insight. Link to comment Share on other sites More sharing options...
TROGDOR! Posted June 15, 2004 Share Posted June 15, 2004 No, these will not fit. Many compacts us a 4-lug pattern. There are two standard sizes. 4x100 and 4x114.3. Subaru uses a 4x140 pattern which is non-standard. Peugeot is the only other company to use this pattern. Link to comment Share on other sites More sharing options...
Craven Posted June 15, 2004 Share Posted June 15, 2004 Soobs and Pugs are 4 lugs on a 140mm bolt circle( the distance between the two opposite lugs), most all of the rest have a smaller bolt circles 100mm, 114mm and so on. Link to comment Share on other sites More sharing options...
subynut Posted June 15, 2004 Share Posted June 15, 2004 Nope. The Subarus' lug spaceing is different. 144mm, I think. Wereas the others: BMW, Toy, honduh, ford, chevy, etc.. all have a smaller spacing. K? Unfortunatly, Pugs are the only alternitive. Unless U wish to convert to the Toy 6 lug or redrill a set of chevy rims. Link to comment Share on other sites More sharing options...
subynut Posted June 15, 2004 Share Posted June 15, 2004 oops, 140, I knew that! :-\ Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2004 Share Posted June 15, 2004 4 x 5.5" in case anyone is wondering. 6 lug chevy and toyota rims are 6 x 5.5", and this is why we all do the 6 lug conversion, or drill two holes in the chevy rims. Depends on the rim type if you can drill the rim or not. GD Link to comment Share on other sites More sharing options...
the goat Posted June 15, 2004 Author Share Posted June 15, 2004 thanks for the quick replies. Link to comment Share on other sites More sharing options...
calebz Posted June 15, 2004 Share Posted June 15, 2004 Theres a couple of people that have redrilled their hubs to 4x100.. wider aftermarket selection that way. Link to comment Share on other sites More sharing options...
88rxsedan Posted June 15, 2004 Share Posted June 15, 2004 Theres a couple of people that have redrilled their hubs to 4x100.. wider aftermarket selection that way. explain the process please. im interested Link to comment Share on other sites More sharing options...
Aussi Vortex Posted June 15, 2004 Share Posted June 15, 2004 posted this yesterday, and got the explinations - started as a bit off topic, but is very relevent to this thread.. http://www.ultimatesubaru.org/forum/showthread.php?postid=143307#post143307 Posted by: Aussi Vortex Link to comment Share on other sites More sharing options...
SubaRube Posted June 15, 2004 Share Posted June 15, 2004 I'd like to do up some hubs like that, sweet job. Nice flywheel too. http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=ja_en&url=http%3a%2f%2fwww5.ocn.ne.jp%2f%7esmsgkit%2fforester.html Link to comment Share on other sites More sharing options...
subyrally Posted June 15, 2004 Share Posted June 15, 2004 you could always get an adapter, i saw one in a parts catalog. Link to comment Share on other sites More sharing options...
Just a Justy Posted June 29, 2004 Share Posted June 29, 2004 so, an 86 4x4 wagon doesn't have the same bolt pattern as the justy (which is 4x100 by the way)? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2004 Share Posted June 29, 2004 No. Although I fail to see how you read through this thread and still had that question... GD Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 29, 2004 Share Posted June 29, 2004 Do the 6 lug toy rims drop on, or do you have to shift the studs? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2004 Share Posted June 29, 2004 You have to add studs (4) (and remove 2 of the existing ones), or drill two new holes in the rim. Easier to drill holes in the rim IMO. But either way works. GD Link to comment Share on other sites More sharing options...
dave valiant Posted June 29, 2004 Share Posted June 29, 2004 Sorry to hijack but,GD when you drill the Chevy 6 hole rims do you just use a Sube wheel to make a template,line up two holes on the 6 hole with the template and drill.Dave. Link to comment Share on other sites More sharing options...
Guest taprackready Posted June 29, 2004 Share Posted June 29, 2004 Sorry to hijack but,GD when you drill the Chevy 6 hole rims do you just use a Sube wheel to make a template,line up two holes on the 6 hole with the template and drill.Dave. I can't tell if you have a question or are answering the original poster's question. Because I would use a hub, not a wheel to make a template. I'd press out two lugs, bolt the hub to the chevy wheel and mark the wheel to drill two new holes. Bill Link to comment Share on other sites More sharing options...
dave valiant Posted June 29, 2004 Share Posted June 29, 2004 Thanks.I was asking a question.Sorry about any confusion it may have caused. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2004 Share Posted June 29, 2004 Yep - taprack has the right idea. That's what I did. That's the procudure that's been floating around for a while. You can also take the hubs to a machine shop and have them drilled for 6 lugs - they can even spline the holes for the lugs..... Make sure there are not raised bumps where you need to drill on the rim. I've encountered some steel wheels that can't be drilled because the surface isn't flat between the existing holes. GD Link to comment Share on other sites More sharing options...
Just a Justy Posted June 29, 2004 Share Posted June 29, 2004 No. Although I fail to see how you read through this thread and still had that question... GD I was hoping that there may be some other oddball subes out there besides the justy with a 4x100 pattern Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2004 Share Posted June 29, 2004 The Justy isn't fully a soob - thus your confusion I suppose. It was apparently a joint project by Subaru and Isuzu..... the source of the weird lug pattern possibly. It also came with 12" wheels originally. Some of the later ones had 13's tho. GD Link to comment Share on other sites More sharing options...
