logic23 Posted February 16, 2017 Share Posted February 16, 2017 Hello team. I am reaching out before i start spending time diagnosing to see if any of you have run into issues with the 06 era H-6 3.0 engine that has a dead miss on three cylinders. ( 2 , 4 and 6) Just seeing if this is a know issue before i waste time/money. Thanks,Craig Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted February 16, 2017 Share Posted February 16, 2017 I would check grounds first. For all three on one bank to be misfiring that's the first place i would check. Link to comment Share on other sites More sharing options...
logic23 Posted February 16, 2017 Author Share Posted February 16, 2017 It also seems to be burning oil... white smoke out the tailpipe. My thoughts were failed rings/low compression. I just dont know the quirks of this engine. Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted February 16, 2017 Share Posted February 16, 2017 Compression is easy enough to check but was it blowing smoke before the misfire issue? I'm wondering if it isn't just dumping unburned fuel into the exhaust. Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted February 16, 2017 Share Posted February 16, 2017 (edited) Compression is easy enough to check but was it blowing smoke before the misfire issue? I'm wondering if it isn't just dumping unburned fuel into the exhaust. If you pulled the plugs and the tube seals are leaking that could also cause it to smoke for a little while. Edited February 16, 2017 by GreaseMonkey03 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 17, 2017 Share Posted February 17, 2017 how many miles on this engine? has it been properly maintained? Link to comment Share on other sites More sharing options...
idosubaru Posted February 17, 2017 Share Posted February 17, 2017 all 3 failing in nearly similar fashion is interesting. extensive carbon build up in the intake/valves/combustion chamber is my first guess based on experience. Random guessing: would timing chain tensioner issues impact timing/cam sensor? FPR - can those affect one side? Unlikely but if someone hacked a spark plug job the plugs, coil packs, could be problematic. Make sure they're replaced (wouldn't be the first time i've seen half of spark plugs replaced), COP's seated and not installed on the wrong cylinder (which they're so tight i'm not sure that's even possible). Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted February 17, 2017 Share Posted February 17, 2017 Anything related to cam/crank sensors would throw a code. I'm guessing he checked codes because he knows which cylinders are misfiring. These are coil over plug, the likelihood of all three coils or plugs going at once is unlikely. Ditto on the carbon build up. One or possibly two cylinders could possibly be affected but the likelihood of three and all on the same bank is also unlikely. You will want to look for ONE issue that will by itself cause all three cylinders on one bank to misfire. That's really where you want to start. It could be a ground, a vacuum leak (although this will usually be accompanied by a random multiple misfire code or affect both banks) or even a break in the harness (those pesky mice might be at it again) For multiple individual components (like valves) to foul up on one bank only and all at once is damn near impossible. Keep it simple. Check the small stuff and go from there. I put a Japanese motor into an American TriBeCa not too long ago. These motors really aren't that complex. Aside from having to swap over a few components, they're simple creatures. If you have a scanner, check for pending codes or history codes. There may be some hidden gems in there that could give you more information. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 17, 2017 Share Posted February 17, 2017 fuel rail is common - and I think it has it's own regulator/pulse absorber gadget valve advance system is common, but I'd expect a code other than just misfire. Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 17, 2017 Share Posted February 17, 2017 On 2/17/2017 at 5:17 PM, 1 Lucky Texan said: fuel rail is common - and I think it has it's own regulator/pulse absorber gadget valve advance system is common, but I'd expect a code other than just misfire. Not always. If head work has been recently done and some of the oil galley plugs were not put in, it can cause a misfire on all 3 cylinders on one bank without throwing any VVT codes. I've found out from experience on that one. How many miles are on the car? When was the last time the spark plugs were changed? What brand and grade of gas is typically used in this vehicle? What is your oil change intervals? The second generation EZ30 are known for cracking heads from the cooLing system into the combustion chamber as well. Have replaced a pair of heads on one engine, replaced a head on another, and replaced an entire engine because of this problem. 1 Link to comment Share on other sites More sharing options...
