ferp420 Posted March 11, 2017 Share Posted March 11, 2017 I am running a snorkel on my ea82 wheeler I had no negative affects from it I have run it with just the stock parts removed but I keeped getting soggy filter that stopped after I put the snorkel on I did gain a bit of performance too and true cold air intake You can avoid soggy filter if you don't cut your fenders and remove the plastic using the stock air box everything works like its saposed to the stock filter set up flows more than enuff air to feed the ea82 no matter how much you hop it up Quote Link to comment Share on other sites More sharing options...
