MR_Loyale Posted February 19, 2017 Share Posted February 19, 2017 I have coolant leaking like a fountain from around the pcv threads on my Loyale. It only shoots out when the engne is revved to above 3000 rpms or so. Under idle it is dry. Just a pcv replacement or something more ominous? I have never seen this happen before. Link to comment Share on other sites More sharing options...
Naked Buell Posted February 19, 2017 Share Posted February 19, 2017 Reseal the threads. If it stills leaks, check to see if there is a crack in the pcv. Link to comment Share on other sites More sharing options...
DaveT Posted February 20, 2017 Share Posted February 20, 2017 Doesn't make sense. Pcv doesn't do anything with coolant. ... 1 Link to comment Share on other sites More sharing options...
TomRhere Posted February 20, 2017 Share Posted February 20, 2017 Pin-hole leak in one of the coolant lines/hoses, and the stream just happens to land near the PVC is my guess. Link to comment Share on other sites More sharing options...
MR_Loyale Posted February 20, 2017 Author Share Posted February 20, 2017 (edited) No it stream out like a fountain when I Rev the engine. Let me try to get a bid or pic tonight. Edited February 20, 2017 by MR_Loyale Link to comment Share on other sites More sharing options...
TomRhere Posted February 20, 2017 Share Posted February 20, 2017 Well if it is coming from the PCV threads, that manifold has serious issues, as in casting flaw that cracked into the coolant passage on the bottom of the manifold. Link to comment Share on other sites More sharing options...
87subbomber Posted February 20, 2017 Share Posted February 20, 2017 you need a new intake manifold buddy. theres a crack in that sucker. Link to comment Share on other sites More sharing options...
