panic alarm can not turn off
Do your neighbors a favor and cut the wires going to the alarm siren/horn. I did that and they thanked me. I can still arm the alarm which causes the headlights to flash and lock the ignition when the alarm is tripped.
as to your problem: check the battery and try to reprogram the FOB
Edited by bstone
My son's Honda Accord did the same thing.
The solution was to lock and unlock the door manually with the key a couple times. He was able to get in and start the car without the alarm going off after that.
Its a long shot but worth a try. Many alarms have some sort of "reset" feature which requires the cycling of a key in a lock or ignition.
