sidecarDoug Posted February 22, 2017 Share Posted February 22, 2017 I had just replaced timing belt on 09 Forester, and somehow managed to destroy the key when tightening the crank pulley / balancer. Part of the key is embedded in the backside of the balancer partially in the keyway, and the remains is smashed up against the crankshaft sprocket that drives the timing belt, and at the top is spread out to about 6.5 mm in width vs, the approx 5 mm width of the keyway. Not much to try and grip onto, and I wanted to get an idea of the options open to me to get the remains of the key out so I can install a new balancer, Has any one run into this situation before ? Thanks for any help you can provide ! Doug If needed, I will try to post a couple of photos tomorrow - right now it's dark and snowing.. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 22, 2017 Share Posted February 22, 2017 (edited) Die grinder with a cut off wheel. You'll have to grind it down till you can get the sprocket off the crank. Destroy the sprocket if you have to. They are only about $35 from the dealer. Key is cheap too. GD Edited February 22, 2017 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
sidecarDoug Posted February 22, 2017 Author Share Posted February 22, 2017 After grinding down key, what is best way to remove sprocket and the part of the key still embedded in the crank? Thanks, Doug Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 22, 2017 Share Posted February 22, 2017 There are holes in the sprocket that are exactly the correct size for tapping to 8x1.25mm thread. Use a steering wheel puller to remove the sprocket. The key will come right out once the sprocket is removed. GD Quote Link to comment Share on other sites More sharing options...
sidecarDoug Posted February 22, 2017 Author Share Posted February 22, 2017 Thanks, General ! Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted February 22, 2017 Share Posted February 22, 2017 Don't forget to use a cutting fluid when tapping those holes. If you have a good hardware nearby, they'll have something. If not, just search online for "tapping fluid" just about anything that comes up will work fine. Once you have the pieces apart, if you can see the broken pieces of the woodruff key, try knocking them out with a flathead screwdriver you don't care about. If you're feeling brave, WD40 will do in a pinch, just make sure you're using a new tap Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 22, 2017 Share Posted February 22, 2017 Tap into the key with a small chisel and use that to pry the key out. New key should slip right in. Quote Link to comment Share on other sites More sharing options...
xdeadeye1 Posted February 22, 2017 Share Posted February 22, 2017 pics at bottom of page 2 http://www.ultimatesubaru.org/forum/topic/149417-harmonic-balancer-quit-spinning/page-2 i think i used a 7mm tap. Bolts that work are hard to find at 7mm though. seriously this was on 96 legacy 2.2 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 22, 2017 Share Posted February 22, 2017 The holes are the correct size for an 8mm x 1.25 tap. NOT 7mm. GD Quote Link to comment Share on other sites More sharing options...
