rae houghton Posted February 22, 2017 Share Posted February 22, 2017 1990 Subaru sportswagon (L series or a Leone depending who you are talking to) single carby. Pulling out of shopping centre , apply brakes , engine stops immediately. ODD I thought turned the key and started up (simple, no issues (new battery)) and drove home. parked, idled, no problem. Next day, wife goes shopping same thing happens multiple times when she takes foot off pedal to apply brake. has to start car again. I look under the hood / bonnet and clean distributor cap (but it didn't need it , as I had done a job on it not that long ago) I start the car ...stops immediately take foot off pedal. 1/2 hour later I am playing around again after looking in my manual. This time starts. Over and over again...no problem.I tell my wife, and she goes out with the car...and comes back 5 minutes later...it is doing it again. I try in the driveway...and same. i try again letting pedal down slowly and it is OK and idles fine. I try again , push down hard and let foot off pedal quickly,,,,,slows to a quick idle. Try again...slows to a gentle idle. Any suggestions? there is a plug in the carby that has some rubber or something covering a screw . This is the idle adjusting screw....and taking the plug out, I was able to adjust the idling up and down....but I don't think that is the problem....or it would have cut out quickly when I slowed it down. I took it out for a spin....and no problems. But I am concerned....As my wife is leery about driving it now. Can I pick your collective thoughts, so that I might try a few things. Perhaps a can of compressed air...shot here and there. ? your ideas are welcome. thanks rae Quote Link to comment Share on other sites More sharing options...
Dee2 Posted February 22, 2017 Share Posted February 22, 2017 Is the brake pedal/arm tangled against any wires under the dash ? Quote Link to comment Share on other sites More sharing options...
rae houghton Posted February 22, 2017 Author Share Posted February 22, 2017 Thanks for the suggestion...I went out after reading it and gave a thorough check... No... no wires to be seen. thanks again Quote Link to comment Share on other sites More sharing options...
Dee2 Posted February 22, 2017 Share Posted February 22, 2017 (edited) ...apply brakes , engine stops immediately... Could be a short somewhere in the electrical system. Somehow the brake may be triggering the problem. Has there been any electrical work done on the car recently ? Any other changes or events occurring before the problem started? One other possibility is the vacuum line to the brake booster. Disconnect it from the engine and plug it and see if the brake problem still occurs. Could be a problem with the brake booster Edited February 22, 2017 by Dee2 Quote Link to comment Share on other sites More sharing options...
Len Dawg Posted February 22, 2017 Share Posted February 22, 2017 (edited) Fuel filter is clogging up..? Float/s are sticking? Edited February 22, 2017 by Len Dawg Quote Link to comment Share on other sites More sharing options...
DaveT Posted February 22, 2017 Share Posted February 22, 2017 Does the carb have any solenoid to help with shutdown? Intermittent wire to that could cause random shut down. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted February 22, 2017 Share Posted February 22, 2017 There is an anti dieseling solenoid that could be causing idle problems . Quote Link to comment Share on other sites More sharing options...
rae houghton Posted February 22, 2017 Author Share Posted February 22, 2017 DEE2 is there a brake booster in all these models...I don't see one (not power assisted) Len DAwg Could be...will change filter... float sticking....why would that happen when brake applied (at very slow speed)? Dave T and ivantruckman There are two sets of wires ..one going to thermostat and second just below...I am guessing this is the solenoid you are referring to. (there are no other wires going to carby) I do have a second carby....that I could fit. ( a lot of tubes and such to do....but maybe that is the way to be sure) All other ideas also welcomed and will be processed and possibly done....before I get to work on exchanging carby. (not sure I can change it without making myself more trouble) thanks all Quote Link to comment Share on other sites More sharing options...
Dee2 Posted February 22, 2017 Share Posted February 22, 2017 I assume there is a brake booster. Most vehicles have one. It's the big round thing by the brake master cylinder. Google "subaru leone brake booster" and look at the images to see what it looks like. There is a rubber hose coming off the booster that goes to the engine. Disconnect it from the booster, plug it and then see if the problem is resolved. Quote Link to comment Share on other sites More sharing options...
DaveT Posted February 23, 2017 Share Posted February 23, 2017 I'm going from memory... Iirc, the carb had an electric choke heater, and a anti diesel valve. 1 wire to each. You can test the valve by unhooking the wire, and applying 12V to it. It should click, and you can try running it. Quote Link to comment Share on other sites More sharing options...
