Starlite Posted December 4, 2017 Author Share Posted December 4, 2017 Two times i have changed the headgaskets and i see this again. There was nothing in the begining but now its increasing and i have to ad about 1dl cooland once a week. Its just the same as the last time i changed headgaskets. Link to comment Share on other sites More sharing options...
Dee2 Posted December 4, 2017 Share Posted December 4, 2017 Two times i have changed the headgaskets and i see this again. There was nothing in the begining but now its increasing and i have to ad about 1dl cooland once a week. Its just the same as the last time i changed headgaskets. You may have a cracked head. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 4, 2017 Share Posted December 4, 2017 Two times i have changed the headgaskets and i see this again. There was nothing in the begining but now its increasing and i have to ad about 1dl cooland once a week. Its just the same as the last time i changed headgaskets. This is not unusual - it's from short trips, and inoperative PCV system. It does not indicate coolant loss. That is condensation. GD Link to comment Share on other sites More sharing options...
Starlite Posted December 6, 2017 Author Share Posted December 6, 2017 Today when driving i hear this woshing running water sound from the heater core. Open the hood and noticed the coolant level on the expansion was about 1-2 cm higher than usual. Open up the radiatorcap and expected an explotion of coolant but nothing. Link to comment Share on other sites More sharing options...
DaveT Posted December 6, 2017 Share Posted December 6, 2017 Those are part of an indication of failing head gaskets. You need to be checking coolant level in the radiator and the overflow before every drive to be more certain. Don't open the radiator cap unless it is low on coolant. The system needs to be 100% full of coolant, little to no air. Link to comment Share on other sites More sharing options...
Starlite Posted December 7, 2017 Author Share Posted December 7, 2017 Now im getting tierd. Second time headgasket failure. Next time i will change engine to another one from my spair part car .....with headgasket failure. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2017 Share Posted December 7, 2017 Its more likely intake manifold gaskets or carb base gasket, etc. GD Link to comment Share on other sites More sharing options...
cnc Posted December 8, 2017 Share Posted December 8, 2017 Fell pro Perma torq , no need for warming up and re torqueing . follow the three torque sequences , then add a final step using 50 ft lbs . felpro part number 9392pt I second that. On a boxer engine, you don't have access to the head bolts to retorque them. With NeverTorques, you don't have to, because they don't relax over time. When they relax, there's less clamping action and they get blow-by and fail. cnc Link to comment Share on other sites More sharing options...
