dp213 Posted February 23, 2017 Share Posted February 23, 2017 I had a bad tranny in my 98 GT so I bought a JDM from a local company. The prblem I am having is it's blowing gear oil from the breather tube on the front diff. The oil level is correct, I checked that first. Other than that dripping onto the exhaust it seems fine. Any ideas? Thanks Link to comment Share on other sites More sharing options...
idosubaru Posted February 23, 2017 Share Posted February 23, 2017 1. AUTO or manual? 2. Oil level is correct - which oil did you check - front diff, ATF, or gear oil? 3. are you absolutely positive it's the correct fluid type - i presume you filled it, it didn't come pre-filled right? if it's an automatic - make sure front diff has gear oil at proper level and ATF is properly filled in transmission. People sometimes confuse the ATF and gear oil on automatics. Manual trans shares gear oil between the front diff and gear set in the trans and just has one fill/dipstick for the gear oil. 1 Link to comment Share on other sites More sharing options...
dp213 Posted February 23, 2017 Author Share Posted February 23, 2017 It's an auto and all fluids are correct and at the right level. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 23, 2017 Share Posted February 23, 2017 (edited) could dipsticks have somehow been swapped or be incorrect? any chance of radiator coolant being pushed thru a leaking trans cooler? Edited February 23, 2017 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
idosubaru Posted February 23, 2017 Share Posted February 23, 2017 1. the fluids are incorrect (type, location, or quantity) 2. ATF is pushing past seals into the front diff, overfilling it and thereby pushing it out the diff breather. You won't notice any fluid issues right away because the gear oil masks the ATF and ATF quantity is nearly 10x that of the front diff. Just keep topping off the gear oil and eventually you'll notice the ATF is loosing fluid. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 25, 2017 Share Posted February 25, 2017 What kind of gear oil did you put in it? Brand? Grade? Synthetic or conventional? Link to comment Share on other sites More sharing options...
dp213 Posted February 25, 2017 Author Share Posted February 25, 2017 Don't remember, got it from the shop I bought the tranny from. It was what they (require). Link to comment Share on other sites More sharing options...
