87subbomber Posted February 25, 2017 Share Posted February 25, 2017 ok so i havent had time to do a leakdown test or compression test yet, but i have coolant in the exhaust. this is a weber converted ea82 car. i figured worst case scenario is a blown headgasket, but oil is not milky. leads me to another thing, coolant passage for carb is not welded or even jb welded. this is a weber conversion so theres still a coolant passage below the carb. if the carb gasket blows im assuming coolant can flow into the intake manifold? Link to comment Share on other sites More sharing options...
Sapper 157 Posted February 25, 2017 Share Posted February 25, 2017 (edited) ok so i havent had time to do a leakdown test or compression test yet, but i have coolant in the exhaust. this is a weber converted ea82 car. i figured worst case scenario is a blown headgasket, but oil is not milky. leads me to another thing, coolant passage for carb is not welded or even jb welded. this is a weber conversion so theres still a coolant passage below the carb. if the carb gasket blows im assuming coolant can flow into the intake manifold?Check out step 4 of the installation procedure http://www.ultimatesubaru.org/forum/topic/161649-ea81-weber-conversion-writeup/?do=findComment&comment=1347335You're supposed to seal the coolant passage with JB weld or use traditional welding to shut the hole Edited February 25, 2017 by Sapper 157 Link to comment Share on other sites More sharing options...
87subbomber Posted February 26, 2017 Author Share Posted February 26, 2017 so after investigating, it was not leaking from the coolant passage. is there any other place that would drain coolant and cause the car to pour white coolant smoke out other than a headgasket? Link to comment Share on other sites More sharing options...
scoobiedubie Posted February 26, 2017 Share Posted February 26, 2017 A cracked turbo, a cracked middle fin in the exhaust port, loose intake manifold bolts to the cylinder heads, and leaking intake manifold gaskets will all cause white smoke to billow out of the exhaust. Link to comment Share on other sites More sharing options...
87subbomber Posted February 26, 2017 Author Share Posted February 26, 2017 thanks for the info, this isnt just a light flow of smoke, this looks like a volcano erupting smoke, only white Link to comment Share on other sites More sharing options...
