colinmi Posted February 26, 2017 Share Posted February 26, 2017 Today I had the front end lifted working on the brakes. When I rotated one wheel the other one turned the opposite direction -as expected. There was about 5-10 degrees of backlash. The wheel will rotate that far before the other one starts to turn. I am fairly new to Subaru and my question is if this in the normal range? The car drives well but seems a little bit louder in front than my wife's 2012 Outback. I know there are other things that could account for this but am looking to learn a little more about these machines. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 26, 2017 Share Posted February 26, 2017 sounds about right to me. Link to comment Share on other sites More sharing options...
lostinthe202 Posted February 26, 2017 Share Posted February 26, 2017 (edited) I don't know the numbers for the diff backlash, but there def is some. If you're gauging the backlash by how much the tire rotates, remember that the rotation of the axle at the axle's diameter of something like 1.25" inches and the tire at something like like 24" is going to look dramatically different. Watch an analog clock that has a second hand. The tip shows much more movement than a point on the hand close to the hub. Add to that motion that when you rotate the tire, you're not only taking up the backlash for the side you're rotating, but also the backlash for the tire on the other side of the diff. Do you have access to another vehicle? Jack that one up and do the same thing, bet you see the same motion. Edited February 26, 2017 by lostinthe202 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 26, 2017 Share Posted February 26, 2017 That would be spider gear backlash added to ring and pinion which is typically a pretty loose situation. You can't tell anything from that. Ring gear backlash alone would be in the .010" range but spider gears in the diff are often pretty loose. GD Link to comment Share on other sites More sharing options...
idosubaru Posted February 26, 2017 Share Posted February 26, 2017 Practically speaking that's inconsequential as a diagnostic tool. First step is to check the fluid Second step is to look at mileage and fluid changes Third is to sit in drivers and passengers seat and stand outside the vehicle while it's being driven past to determine if the noise is more left/right or central. Link to comment Share on other sites More sharing options...
colinmi Posted February 27, 2017 Author Share Posted February 27, 2017 Thank you for all the responses. Because of them I learned a bit about the car. It's good to know this backlash isn't an indicator of something going bad. I also did a little more practical diagnosis here and am reasonably sure that these tires are why things are slightly less quiet and smooth than I think they could be. An alignment and some fresh tires are in my future I think. Thanks again. Link to comment Share on other sites More sharing options...
