06SubLegTx Posted February 26, 2017 Share Posted February 26, 2017 Hello, The car I recently purchased has 96,000 on it. 2006 Legacy has a small issue that I have noticed. When I am pull up to a traffic light the engine rpm's drop down to the point I think it may want to stall. This is more prevalent when the A/C is on, but it still does it a little less when it is off. I have read that the IAC (Idle Control Valve) sometimes get clogged/restricted a little. Can the EGR also cause this? Thanks for any help Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 26, 2017 Share Posted February 26, 2017 It does not have an idle control. It has a drive by wire throttle body. One of the common problems we see is these getting dirty and not responding the way the computer asks. It is most prevalent with 05/06/07 DBW throttle bodies. You can try cleaning it with induction cleaner but if that doesn't work a new throttle body will be needed. They ain't cheap. GD Quote Link to comment Share on other sites More sharing options...
06SubLegTx Posted February 27, 2017 Author Share Posted February 27, 2017 I will try that. It looks like one was done already (the new gasket looks very clean/new.) I will get some throttle body cleaner, and let you all know if it works. Thanks for your help.. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 27, 2017 Share Posted February 27, 2017 (edited) unless done in the last coupla years, your car is due for a timing belt system service. Edited February 27, 2017 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
06SubLegTx Posted February 27, 2017 Author Share Posted February 27, 2017 unless done in the last coupla years, your car is due for a timing belt system service. Hello, Yea, I am going to purchase all the parts in a week and do it. Does someone make a special shop tool for the cam seals? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 27, 2017 Share Posted February 27, 2017 Shop tool for installation? Yes Subaru makes them through Kent Moore. They are about $45 IIRC. Special order. You don't need it though. GD 1 Quote Link to comment Share on other sites More sharing options...
