Considering Selling...
So I have this 89 gl coupe. I have swapped an ej22 and the entire 95 legacy front suspension into it. It needs rear wheel adapters (about 300 each from my local machine shop) the wiring harness needs tied and tucked, the trans bump needs covered, coolant hoses need to be rigged, the two electric fans need to be mounted and wired, fuel pump needs wired through a switch, and I'd recommend an ignition button/ switch. Is anyone willing to take on the challenge? As far as body work and paint, I did it all two year ago. It is Viper Blue and has red mudflaps on it. I dont know how much I would sell it for. I just want to know if anyone would be interested in a new project.
I forgot to add that I did have it running once. I haven't tried since. Once it is completely tied up and running, I would recommend a new crankshaft. The typical thing with this generation of ej is that they sheer the keyway for the crank pulley. So a coworker of mine welded it on. Obviously it is not perfectly straight on there, so I would just recommend a new one.
