Pretty easy to do over all. Pull the 2.5. Swap the 2.5 flexplate in place of the 2.2 flywheel.  Install the 2.2.
You'll either need to swap the 2.5 wiring, etc. over to the 2.2 intake manifold which should run fine but throw an EGR code. OR - the easier way would be to find an intake manifold from a 95-98 automatic 2.2 that is EGR equipped and bolt that to your 2.2 - there's an easy workaround to run a hose so there's no check engine light. Pick n pull is your friend.
You can get the step by step remove and reinstall here.
http://www.ultimatesubaru.org/forum/topic/159902-1990-2004-ej18-ej22-ej25-diy-complete-engine-remove-and-reinstall-guide/
