dp213 Posted March 2, 2017 Share Posted March 2, 2017 I pulled the oil pump off the motor I picked to clean it and check the screws and reader the o ring. What I am wondering is there a gasket for the whole pump or should I put a thin coat of sealer or nothing at all. Link to comment Share on other sites More sharing options...
ocei77 Posted March 2, 2017 Share Posted March 2, 2017 replace the o ring and front crank seal, use sealant on the pump. Don't overdo it on the sealant. Torque spec on the bolts is only 4.7 ft lbs. O. Link to comment Share on other sites More sharing options...
lmdew Posted March 2, 2017 Share Posted March 2, 2017 Gray RTV, just a very thin coat. I always let mine cure for 24 hours after the install. Link to comment Share on other sites More sharing options...
dp213 Posted March 2, 2017 Author Share Posted March 2, 2017 Thank you Link to comment Share on other sites More sharing options...
